Cleaned the engine bay, now car running poorly.
Old Jul 23, 2008 | 11:00 AM
Jdmon079's Avatar
Default Cleaned the engine bay, now car running poorly.
I read up on the thread to clean the engine bay and motor w/ degreaser. So i covered all the necessary parts, intake, distributer, alternator, fusebox, etc. Degreased the engine, sprayed it down w/ water. Go to drive it away, and the car wants to shut off. The car is now idling fine, but when i go do drive off, I car hisitates like crazy in the lower RPMs. I checked the distributer and plugs, but no water. Im hoping any water didnt get into the intake. If anyone could shoot some ideas at me, I'd appreciate it.
Old Jul 23, 2008 | 11:23 AM
Jdmon079's Avatar
Default Re: Cleaned the engine bay, now car running poorly. (Jdmon079)
Edit: Sprayed out some water out of the sparkplug area and beat on the car a little bit. It came back to life.
Old Jul 23, 2008 | 11:38 AM
redef90si's Avatar
nextime make sure it's running when you "detail" The engine bay i didn't the first time i did it and got water in an injector somehow,not a fun experience.
Old Jul 23, 2008 | 12:46 PM
blk92_d16's Avatar
Next time, just use a can of engine clean and a used toothbrush. i don't rinse at all to avoid this problem.
Old Jul 23, 2008 | 12:51 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: (blk92_d16)
orly... I detailed mine last night and I'm having the exact same problem. Done it dozens of times before, and it's never done this.
DAMN YOU H-T GET OUT OF MY HEAD!!!
Have to check under plug cover when I get back to the car.
blk92_d16, you seriously use a toothbrush? I used to do it that way until I got tired of it taking 3 hours everytime I wanted to clean my engine.
Old Jul 23, 2008 | 01:40 PM
hondaman1212's Avatar
Default Re: (Vindicator9000)
kinda off subject but i like your thing at the bottom that says you hope your boss doesnt say honda tech.com lol we arent supposed to be on the computer at work either especially at honda tech.they say they log the sites but i come here a couple times a day at work so i feel you.
Old Jul 24, 2008 | 05:03 AM
Default Re: (hondaman1212)
Holy crap, my car is STILL running like ***... and this swap was running great for the last 2 weeks since I put it in.
What could I have gotten water into that I shouldn't have? It seems to run fine below about 15% throttle. Above that, it bucks and kicks. Sometimes it'll smooth out for a second, but then starts again.
I would say that it's definitely dependent on the throttle, but it's also idling rough and low sometimes... under 500 rpm. Acts like it wants to stall, then kicks back up to 800 steady and will smooth out.
I found and cleaned out some water from the IAT plug, but everything else looks okay. Checked injector plugs, under dizzy cap, under plug cover, can't find any more water. Any ideas?
Old Jul 24, 2008 | 07:31 AM
Well, I learned something today. Apparently the B-series sparkplug cover is cosmetic only, and does absolutely nothing to keep water from the plugwells.
I vacuumed water from the plugwells and wires and put in new plugs. Runs like a champ now.
Modified by Vindicator9000 at 6:43 PM 7/24/2008
Old Jul 29, 2008 | 03:30 PM
Jdmon079's Avatar
Yea dude. I had to do the same ****. I thought the same. Yours still running good? Mines still alive ftmfw.
tbonez
Honda Civic (2006 - 2015)
Dec 7, 2010 09:44 AM
MTK Kommander
Jan 4, 2008 09:11 PM
oem_CD5
Jul 9, 2006 06:28 AM
4doorex
Nov 30, 2004 12:30 PM
JSwiftNyc1
19
Dec 7, 2003 08:01 PM
