Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie
Old Jul 23, 2008 | 10:36 AM
pcorad's Avatar
Default Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie
We replaced the clutch (what a biatch) with OEM. All seemed fine. But I'm getting a little grunch (not quite a crunch) going from 1-2 and 2-3 gears.
Clutch fluid was flushed.
I'm going to change the tranny fluid this weekend, but the grunching definitely seems related to the recent clutch replace.
Old Jul 23, 2008 | 12:49 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie (pcorad)
Replace the tranny fluid with the new Honda MTF and see if that helps. If it doesn't, then you might have some other things going on. 02's were bad for grinding, though--but it was usually only 2-3 and not 1-2.
Old Jul 23, 2008 | 02:25 PM
DC5mike's Avatar
Default Re: Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie (Todd00)
Ive got a little notch when shifting from 1st to 2nd on my 04 type-s. Stock clutch and GM synchrow mesh with friction additives. The tyranny fluid helped for like two weeks then it reverted back to the normal notch I had with the Honda fluid and its really easy to grind 2nd gear so I think i might need to replace those synchrows.
Old Jul 23, 2008 | 02:58 PM
Tyte-S's Avatar
Default Re: Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie (DC5mike)
My '02 is doing fine just a little stiffness sometimes...The Honda MTF definately helps.
Old Jul 24, 2008 | 06:23 AM
pcorad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Replace the tranny fluid with the new Honda MTF and see if that helps. If it doesn't, then you might have some other things going on. 02's were bad for grinding, though--but it was usually only 2-3 and not 1-2.</TD></TR></TABLE>
That sounds like the right plan. When I first bought the 02 type s (brand new) 1-2 was a little notchy, but it went away. I had absolutely no grunchie issues prior to the clutch change, so I'm a little bummed.
If the fluid flush doesn't work, what are the likely causes stemming from the clutch replacement?
Old Jul 24, 2008 | 05:51 PM
B18CXr's Avatar
make sure you use proper lubrication on the input sleeve and NOT on the splines
Old Jul 26, 2008 | 10:43 AM
thetunersource's Avatar
Default Re: Clutch Replaced - Now 2nd and 3rd Gear are a little Crunchie (B18CXr)
my ep3 tranny is dying, i think!
Old Jul 28, 2008 | 08:40 AM
pcorad's Avatar
So, I changed the tranny fluid this weekend. When I opened drain bolt, I was surpised at how much force the fluid came out. Turns out there as 1.6 GALLONS of tranny fluid in there, not 1.6 quarts. I have to assume my mechanic who did the clutch overfilled cause I've never changed the fluid before.
The tranny shifts just fine now.
Old Jul 28, 2008 | 10:17 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad &raquo;</TD></TR><TR><TD CLASS="quote">
The tranny shifts just fine now. </TD></TR></TABLE>
How in the hell did they get 1.6 gallons in there? Must have been pretty messy, especially when screwing on the fill-bolt.
Old Jul 28, 2008 | 05:42 PM
pcorad's Avatar
I'm going to assume my mechanic filled it up via the VSS (not that I've ever done it that way, but it sounds like you could overfill via the VSS).
Maybe he mixed up his gallons and quarts? He can be a good mechanic, when I hover over him...
phelpsj2
Mar 7, 2011 12:04 PM
niceprelude
Nov 7, 2008 10:22 AM
DC5Danny
Jan 21, 2008 08:36 AM
gooberwolf
Apr 11, 2007 07:27 PM
shiux
Mar 19, 2006 06:53 PM
