brake conv. parts list request.
i own a 1994 civic dx hatchback and i want to do a brake swap. there are a few posts in the archives, but i just want straight forward and most direct information i can get. can someone please give me a list of brake components i will need to do a fully functional brake swap? in list form would be ideal. this info would be very much appreciated.
picture for good measure.
- Knuckle assembly
- Trailing arm assembly
- Prop valve
- Larger master cylinder
For more details, please use the search function.
- Prop valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cdriver »</TD></TR><TR><TD CLASS="quote">
What exactly is the picture for?
It would help if you would tell people what sort of brake conversion you want to do.....
Upgrade front brakes? Rear disc conversion?
BTW, H-T has just about best search function out of all the forums on the web.
HMotorsOnline.com offers front and rear brake upgrade/conversions. I bought the GSR front brake conversion from them and it was 100 bucks (plus shipping, tax). That included everything (knuckle, caliper, rotor, and upper control arm). You'll just need new brake lines and the maybe the rotors turned. Rear conversions include e-brake cables. Same with the front. New lines, and rotor work. Rear conversion is 200. 40/40 prop valve is a good idea too. Hope that helps, and good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SarahVTEC »</TD></TR><TR><TD CLASS="quote">'nuff said
https://honda-tech.com/zerothread?id=1811368</TD></TR></TABLE>
thanks for the link!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JConto »</TD></TR><TR><TD CLASS="quote">HMotorsOnline.com offers front and rear brake upgrade/conversions. I bought the GSR front brake conversion from them and it was 100 bucks (plus shipping, tax). That included everything (knuckle, caliper, rotor, and upper control arm). You'll just need new brake lines and the maybe the rotors turned. Rear conversions include e-brake cables. Same with the front. New lines, and rotor work. Rear conversion is 200. 40/40 prop valve is a good idea too. Hope that helps, and good luck.</TD></TR></TABLE>
great info! thanks for sharing your personal experience and also giving me your source.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe »</TD></TR><TR><TD CLASS="quote">
what a helpful response.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">
BTW, H-T has just about best search function out of all the forums on the web. </TD></TR></TABLE>
well, the picture is up there simply because i like to look at my cars.
as for what kind of swap, i just assumed that they pretty much all had the same components and i was going to decide what swap was best for me after reviewing the helpful responses. what i had in mind was a front and rear brake conversion from a gsr or 00' si. thanks for your reply.
</TD></TR></TABLE>what a helpful response.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">What exactly is the picture for?
djrico724
Suspension & Brakes
Jun 3, 2008 04:22 PM
racer_X_123
Mar 24, 2006 09:37 PM
TedR719
Sep 10, 2004 03:59 PM
devoxtekxhb
Jan 28, 2003 11:39 PM
