Wheel Hub & Bearing
Old Jul 22, 2008 | 12:59 PM
shadhman's Avatar
Default Wheel Hub & Bearing
Hi,
It seems like my rear wheel bearings are going out(they howl). Should I replace the wheel hub as well while im at it? If so is there an aftermarket brand that you guys like? What are the benefits?Throw me a site if possible
Vehicle is a 94 Del Sol Vtec (Yes with Discs on the back)
Old Jul 22, 2008 | 02:06 PM
immajackuup's Avatar
Default Re: Wheel Hub & Bearing (shadhman)
buy the hub bearing assy.
rear bearing are different from the front.
Old Jul 22, 2008 | 02:39 PM
instructor74's Avatar
you have to they are an assembly
Old Jul 22, 2008 | 02:53 PM
shadhman's Avatar
Default Re: Wheel Hub & Bearing (instructor74)
oh no ****
i thought that you could just get the bearings pressed in.
Is there a better after market one I should look at? If so link me if not where do you suggest I buy them from.
Old Jul 22, 2008 | 03:37 PM
1992Si's Avatar
http://www.hondaautomotivepart...EC%29
Here's where to find out how, delsol's may be in the civic manual, I just checked mine, no. But the rear bearings must be the same as a Si
http://hondatech.info/downloads/Auto/Manuals/
http://www.partsamerica.com/Pr...Set=A
Modified by 1992Si at 7:46 PM 7/22/2008
Old Jul 22, 2008 | 04:20 PM
shadhman's Avatar
Default Re: Wheel Hub & Bearing (1992Si)
So all i need is the bearing assembly?
Put it in and no more howl?
Old Jul 22, 2008 | 04:34 PM
1992Si's Avatar
They recommend you replace the axle nut as well.
If you've never broken torque on an axle nut, you want to break torque with the car on the ground, it's 134ftlbs. If it's like the front nut it takes a 32mm socket, get a 1/2" breaker bar and a 3 ft pipe or a 3/4" impact gun with at least 150psi of air.
Old Jul 22, 2008 | 08:57 PM
shadhman's Avatar
k, great thanks for the advice! Aren't you on D-series org?
Vladvyg
Honda Civic (2006 - 2015)
Jul 4, 2015 05:23 AM
PaChiLa Leader
Feb 18, 2009 05:21 PM
lowtegsr
Jan 31, 2008 04:30 PM
redman223
Apr 30, 2007 02:36 PM
nwdrifter
Sep 28, 2004 12:15 PM
