Oil leak/spray at high rpm's
Old Jul 22, 2008 | 10:04 AM
inspector01's Avatar
Default Oil leak/spray at high rpm's
My B18C1 started to leak oil pretty decently and i can't figure out where it is coming from. It is on the back of the block and seems to be between the filter and the PCV black box. It is spraying out onto the firewall and bottom of the intake manifold only when driven hard, at idle it doesn't leak at all.
Im trying to figure out where it could come from, i can only think of the oil pressure sensor hole (my oil feed line goes there and it seems clean), the filter/sandwich/cooler, which all seem to have good gaskets, and then the PCV black box. Any ideas where it could come from??
Old Jul 30, 2008 | 11:50 AM
miguel329's Avatar
Default Re: Oil leak/spray at high rpm's (inspector01)
im having the same issure with a gsr aswell cant find it
Old Jul 30, 2008 | 12:31 PM
I found it on my car. There was a threaded hole behind the PCV black box that was open and blowing out oil. I put a bolt in it and it is fine now, it is right behind the black box so pull that black box off and put a bolt in it if it is the same as mine.
Old Jul 30, 2008 | 01:58 PM
h0ndamatix's Avatar
Default Re: (inspector01)
Does your engine have the siphon hose coming from the oil filter area that goes to the vtec solenoid/oil supply?
Old Jul 30, 2008 | 03:55 PM
miguel329's Avatar
Default Re: (h0ndamatix)
im not sure its a 94 gsr engine... i didnt know that some came with a hose..i will look.
Old Jul 31, 2008 | 07:57 AM
h0ndamatix's Avatar
Default Re: (miguel329)
Yea, might wanna check that out. My buddy threw a b20vtec in his delsol, and the pre-filter siphon hose that leads to the vtec solenoid had to be replaced with thousand pound steel braided line. 50-90 psi running through that line at full tilt...was pissin all over the place.
Old Jul 31, 2008 | 08:36 AM
Thats because it was a B20 vtec so you need an external oil feed, GSRs are internal.
Old Jul 31, 2008 | 04:30 PM
miguel329's Avatar
someone told me it could be my axel seals on the tranny side is that possible?
Old Aug 2, 2008 | 07:13 AM
miguel329's Avatar
anyone have a diy on changing the Axle seal
Old Aug 2, 2008 | 02:26 PM
1sikhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspector01 &raquo;</TD></TR><TR><TD CLASS="quote">I found it on my car. There was a threaded hole behind the PCV black box that was open and blowing out oil. I put a bolt in it and it is fine now, it is right behind the black box so pull that black box off and put a bolt in it if it is the same as mine.</TD></TR></TABLE>
do u have a picture of the hole? i got a really bad oil leak and cant figure out where its coming from
raverx3m
Mar 14, 2015 10:12 PM
avotegra
Sep 4, 2008 09:43 AM
1.8T_EG
Jul 30, 2004 07:31 AM
MeanGreenEG9
Feb 4, 2003 02:51 PM
