retorqueing pressureplate
Old Jul 22, 2008 | 09:08 AM
Scheizty's Avatar
Default retorqueing pressureplate
For my turbo h22, I dropped in an ACT stage 3 clutch. The first time that I put the clutch on, I overtorqued the pressure plate bolts to 25 ft-lb. After removing the clutch I checked the torque specs and they were only 19 ft-lb. Using the same bolts, should I overtorque them again, or should I only go to spec?
Old Jul 23, 2008 | 04:50 AM
Boosted_B_Series's Avatar
either should work.. I'd go with the factory tq specs
Old Jul 23, 2008 | 08:37 AM
Scheizty's Avatar
Default Re: (Boosted_B_Series)
That's what I did. Thanks. Just didn't want the pressure plate coming off.
Old Jul 23, 2008 | 08:56 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (Scheizty)
20lbs with red locktite will be fine
reboosted
Oct 4, 2009 07:56 PM
99h22ek
Aug 19, 2006 05:04 PM
h22_crx
May 3, 2006 12:32 PM
Kermit EK
Dec 28, 2002 07:24 AM
