retorqueing pressureplate
For my turbo h22, I dropped in an ACT stage 3 clutch. The first time that I put the clutch on, I overtorqued the pressure plate bolts to 25 ft-lb. After removing the clutch I checked the torque specs and they were only 19 ft-lb. Using the same bolts, should I overtorque them again, or should I only go to spec?
h22_crx
May 3, 2006 12:32 PM
