Rear Swaybar for 96-00 DX Hatch
I've decided that it's time to downsize the aftermarket 22mm rear swaybar. Anyone know what stock sized (~13mm) rear swaybar will fit a 6th Gen Hatchback?
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnCivic2000 »</TD></TR><TR><TD CLASS="quote">I've decided that it's time to downsize the aftermarket 22mm rear swaybar. Anyone know what stock sized (~13mm) rear swaybar will fit a 6th Gen Hatchback?
Thanks!</TD></TR></TABLE>
em1 bar should work
em1 bar should work
EM1? I'm not familiar with that designation. What is that? Thanks.
From the scraps of information that I've sifted through, all roads seem to be pointing to the 1999-2000 Si. I couldn't find anything local, but it looks like http://www.hondaautomotiveparts.com has the bar and the rest of the "parts" for just over $100.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnCivic2000 »</TD></TR><TR><TD CLASS="quote">EM1? I'm not familiar with that designation. What is that? Thanks.
From the scraps of information that I've sifted through, all roads seem to be pointing to the 1999-2000 Si. I couldn't find anything local, but it looks like http://www.hondaautomotiveparts.com has the bar and the rest of the "parts" for just over $100. </TD></TR></TABLE>
em1 is a 99-00 civic si. that has a 14mm sway bar i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">You can use the 99-00 Civic Si rear swaybar, it is a perfect fit! I am using that in my 98 Civic hatchback and it is perfect.
thats what i thought.. but just to clarify, is it 13 or 14 mm?
</TD></TR></TABLE>thats what i thought.. but just to clarify, is it 13 or 14 mm?
According to http://www.hondaautomotiveparts the 2000 Si rear bar 13mm.
Thanks for the help!
Actually, the Progress 22mm bar that I had was a lot of fun on smooth roads. However, here in Pittsburgh there are too many terrible road surfaces (brick, potholes, train tracks, or worse) for that kind of setup on a daily driver vehicle. I found that tiptoeing around got tiresome. From what I'm hearing, the 13mm bar will be a good functional compromise.
big-cat
May 20, 2007 10:58 PM
jetpilot
13
Nov 7, 2003 01:40 PM
