Suspension & Brakes Theory, alignment, spring rates....
00 Integra GSR w/ Koni Yellows and ITR Springs. ----> Passenger side sits higher than Driver side
Old Jul 22, 2008 | 06:36 AM
92integraVTECgsr's Avatar
Default 00 Integra GSR w/ Koni Yellows and ITR Springs. ----> Passenger side sits higher than Driver side
Anyone know why the passenger side would sit just a tad higher than the driver side?
I have Koni Yellows and ITR stock springs. Its only about 1/2 inch difference, but its noticeable to me.
Any ideas?
Old Jul 22, 2008 | 03:00 PM
TunerN00b's Avatar
Default Re: 00 Integra GSR w/ Koni Yellows and ITR Springs. ----> Passenger side sits higher than Driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know why the passenger side would sit just a tad higher than the driver side?
Any ideas?</TD></TR></TABLE>
Are you positive that your car has a 50/50 left/right weight distribution?
I can say my GSR certainly doesn't, and accordingly the driver's side sits lower.
Old Jul 22, 2008 | 03:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I can say my GSR certainly doesn't, and accordingly the driver's side sits lower.</TD></TR></TABLE>
No I'm not positive. So I guess the only way to fix that is coil overs?
Old Jul 22, 2008 | 03:31 PM
R-Lug's Avatar
it is quite common for the passenger side to sit a little higher than the driver side on hondas. Also, make sure that the front strut goes all the way down into the fork
Old Jul 22, 2008 | 03:51 PM
TunerN00b's Avatar
No I'm not positive. So I guess the only way to fix that is coil overs?</TD></TR></TABLE>
If you're willing to trade handling for cosmetics, yes. Raising the heavier corner up to level with the lighter corner will push the corner weights even further "off" than stock.
And I should apologize for my earlier post. A transverse engine FWD car is never balanced left/right, since the engine isn't centered in the chassis.
Old Jul 23, 2008 | 10:18 PM
bmoua's Avatar
when i still had the stock suspension on my 99 civic, the front passenger side was a bit higher than the front driver side. There's a resonable answer for that but unfortuantly i can't answer it for you ahah. All in all, its not a big deal.
Old Jul 24, 2008 | 07:24 AM
ITM901's Avatar
ya, I had the exact same problem with my 98' gsr. The pass. side sat higher than the driver side. Even after lowering it, it still sat higher. Really bugged me at first but I eventually got used to it.
Old Jul 24, 2008 | 08:00 AM
Default Re: (ITM901)
it just sucks because the passenger side has less camber than the driver's side.
Old Jul 24, 2008 | 03:28 PM
TunerN00b's Avatar
Default Re: (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">it just sucks because the passenger side has less camber than the driver's side.
With correct toe settings, this will not be an issue for tire wear.
In terms of being a handling issue, it isn't (enough to worry about anyway).
dpine
Suspension & Brakes
Sep 3, 2008 07:44 AM
92integraVTECgsr
Suspension & Brakes
11
Apr 11, 2008 04:17 PM
92integraVTECgsr
Mar 26, 2008 03:43 PM
CRISIS
Suspension & Brakes
10
Sep 5, 2006 10:18 PM
itrboi
Apr 26, 2003 04:40 PM
