97 USDM ITR in a 97 DX Hatch troubleshooting
Old Jul 20, 2002 | 10:53 PM
nutsack's Avatar
Default 97 USDM ITR in a 97 DX Hatch troubleshooting
helping a friend put a 97 USDM ITR in a 97 DX Hatch. everything installed and wired up. engine starts fine, but idles like crap. only code from the 97 ITR ecu is for the secondary O2 sensor (using a test pipe). engine sounds like its misfiring, runs very rich, and will not rev past 3k rpm. all sensors in correct places and no vacuum leaks. the previous motor in there was a 99 LS motor. the civic harness from the LS motor was put on the ITR motor. would this have anything to do with why its not running correct? thanks in advance!
Old Jul 21, 2002 | 04:40 AM
97hb's Avatar
Default Re: 97 USDM ITR in a 97 DX Hatch troubleshooting (*******)
Check the map and tps and make sure they are not switched.
Old Jul 21, 2002 | 05:41 AM
nutsack's Avatar
Default Re: 97 USDM ITR in a 97 DX Hatch troubleshooting (97hb)
they aren't switched. engine runs the same when they are switched. also the IACV and IAT are not switched.
Old Jul 21, 2002 | 10:13 AM
Jackson's Avatar
It sounds like the IACV wasn't wired properly. Also, check your cam timing and set your idle.
Old Jul 22, 2002 | 02:55 AM
97hb's Avatar
The engine shouldn't run the same if they were switched(should run super rich and stumble after 3000. I bet your problem lies there. Same exact symtoms as mine had, but mine was so rich gas was comming out the exhaust. Switched the two and it ran fine. Also the wire for the iacv should be in pin a12 instead of a14(might be the other way around). Should already be like this if you had the ls motor though. If you have a dx with a teg motor it should be throwing code "91"
[Modified by 97hb, 5:56 AM 7/22/2002]
Old Jul 22, 2002 | 06:59 AM
Evil DOHC's Avatar
What kind of computer are you trying to run?
EVIL
Old Jul 23, 2002 | 07:34 PM
nutsack's Avatar
Default Re: 97 USDM ITR in a 97 DX Hatch troubleshooting (Evil GS-R)
turns out the timing was off by 6 teeth. thanks everyone!
Old Jul 23, 2002 | 08:21 PM
97hb's Avatar
Wow 7 teeth, good thing you didn't bend any valves.
program
Jan 3, 2008 03:14 PM
Victor Penner
Dec 18, 2002 01:44 PM
nEoMuGen
Jul 23, 2001 06:11 PM
