passenger side axle help
I replaced my tranny and the passenger side axle was stuck i got it out but it screwed up the little clip that goes in the tranny. the axle goes in and out good with out clip but will it fall out when i drive it.
just replace the clip, i'm assuming it didn't end up in the transmission somewhere. just go to honda, i belive its called a "circlip" i suspect is about 80 cents. should definately be no more that 2 or 3 dollars.
do u think it will fall out cause its all i got to drive to get the axle clip. drove it for 3 months with out 3rd gear till i got a new tranny.
take a bar with you, if it pops out just use the shock tower as a fulcrum and pop it back in again. Only thing is if it pops out you run the risk of damaging the end of the axle. If it were me i'd try to get a ride with someone.
AnotherEJ
Dec 10, 2008 05:16 PM
Blaze45
Apr 20, 2004 03:35 AM
StockTeg
Jul 30, 2002 01:20 PM
