92 civic with b16 couple issues
Hey guys, don't have a lot of time to be lifting up the car and looking to see whats wrong etc. So this is whats happening, any input is awesome.
1. When shifting and giving maybe quarter throttle the shift kinda pulls when in gear towards the engine, and it also feels a little loose left and right before moving the linkage if you know what I mean.
2. Engine seems to idle a little high, IACV was cleans out thinking maybe and engine flush, or spray some carb cleaner in the intake mani etc. Let it wrong for a bit and burn out all the crap.
Let me know what you guys think, thanks.
try replace the shifter bushings for the shifter... maybe thats why its a little loose, but i dont really know what you are talking about, but it does seem like bushings maybe..
also what is your idle at?
Idle is about 1800-1200 depending. Always after warming up, sorry forgot to mention that.
As for the shifter problem. Imagine u shift gears say from 1st to second, as soon as u let out the clutch and gas it, it stays in gear but kinda moves toward the engine. I am thinking it's the mounts, need to fix it, makes the car feel like ***.
hey guys anything else to add to this? Not really sure what or where the spring pin is located? Let me know, I'm most likely thinking it's the rear mount on the subframe close to the firewal.
hondazccivic
Jul 23, 2008 05:13 PM
Cypher0117
10
Jun 1, 2006 01:15 PM
