b16a2 into 94 civic dx
Old Jul 21, 2008 | 01:16 PM
Civic94DX's Avatar
Default b16a2 into 94 civic dx
hi all,
i have a 1994 civic dx hatchback, broke down over the weekend and found out that i need a new distributor and head gasket, so therefore id rather use that money towards a new engine, as i have wanted to upgrade to a bigger engine at some point.
i have been offered a b16a2 engine and was wondering how easy this is to fit into my car? and what parts do i need for the full conversion? gearbox etc?
any help would be very much appreciated.thanks
Old Jul 21, 2008 | 02:20 PM
94EG8's Avatar
Seagull Management
Default Re: b16a2 into 94 civic dx (Civic94DX)
Its actually pretty easy to fit a B16 in 5th gen civic, some japanese and european models came B16s right from the factory. what you'll need:
- Engine
- Transmission
- ECU (P30)
- Shift Linkage
- mounts
- Some wiring mods (must add vtec and knock sensor wiring)
- Axles
I'm sure theres something i missed, but thats at least the vast majority of whats needed, search around, this is a very common swap and is well documented.
Edit, forgot to add, you will need to repin the distributor plug, get a jumper harness or get an OBD1 distributor.
Old Jul 21, 2008 | 08:13 PM
eg_boi's Avatar
Default Re: b16a2 into 94 civic dx (94EG8)
if its a complete swap with engine harness then all u would need is the t bracket from the integra. if u want to be safe then u can also grab the driver side mount from the block of a b18 also since it has 3 holes instead of 2.
would need a p30 if u want knock sensor or p28 if u dont feel like running knock sensor. you would only need to convert your distributor wiring if u plan on running an obd 1 engine harness because they only run 1 big plug instead of 2. would need to pin out the vtec and knock sensor on ur tower harness by the battery.
quick break down
complete swap + engine harness
b series axles
p30/p28 depending if u want to run knock sensor or not
integra t bracket
integra driver side block mount if u want that extra slot for a screw
wiring the vtec/knock sensor
integra shift linkage if u run into a problem with the a2 shift linkage becuz the b16 has a different curve (only necessary if u're having problems with ur current)
jettman94
Dec 5, 2014 10:30 AM
BLINKY619
29
Oct 28, 2013 06:36 PM
rob taelem
Engine Management and Tuning
Mar 5, 2010 02:20 PM
Perkul8r
Aug 8, 2009 01:30 PM
D1ANCER
Mar 7, 2002 12:39 PM
