Questions mounting an external fuel pump
Old Jul 21, 2008 | 11:23 AM
b16b18's Avatar
Default Questions mounting an external fuel pump
Is it okay to mount the fuel pump (Aeromotive A100) directly to a steel plate and/or the chassis? Should there be rubber in between the pump and the metal to dampen the vibration? Does having the pump touching metal affect grounds or anything? Thanks for the info.
Old Jul 21, 2008 | 11:31 AM
Blown90hatcH's Avatar
Default Re: Questions mounting an external fuel pump (b16b18)
I would highly recommend using rubber mounts. You can get them from summit, Mcmaster-Carr, etc. or make your own vibration isolators.
Old Jul 22, 2008 | 12:04 PM
b16b18's Avatar
Default Re: Questions mounting an external fuel pump (Blown90hatcH)
Can the pump get damaged if it's not mounted with rubber mounts?
Old Jul 22, 2008 | 01:18 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Just use rubber. The vibrations are INSANE without them
Old Jul 22, 2008 | 01:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Questions mounting an external fuel pump (Clayton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clayton &raquo;</TD></TR><TR><TD CLASS="quote">Just use rubber. The vibrations are INSANE without them</TD></TR></TABLE>
for some reason the aeromotive is nasty.
i can handle my weldon pretty well.
Old Jul 22, 2008 | 04:05 PM
1992Si's Avatar
Also be careful when to tighten the terminals, they can spin easy and break the wire on the back. You can send it back and they'll fix it...been there, done that.
Old Jul 22, 2008 | 07:04 PM
b16b18's Avatar
Default Re:
I only brought this topic up because I've been having a heck of a time with this new pump and I'm running out of possible causes. It doesn't seem to maintain pressure or is losing power or something. I've sent it back to Aero for testing, they said it was fine, got it back and it worked perfect for a day or so. Now it's back to the same issue with pressure drops, really rough idle (if the car does manage to even start), and stalling. I've ordered the rubber mount kit and I'll make sure I don't over tighten the terminals. Urgh
Old Jul 22, 2008 | 07:57 PM
a1320addict's Avatar
Default Re: Re: (b16b18)
How are you powering the pump? Sounds like an electrical issue.
I definitely would use a rubber mount, when I had my twin-bosch setup I used brackets made for the pumps on a plate we did and had them wrapped in electrical tape, worked great.
Old Jul 22, 2008 | 08:43 PM
What size wiring are you using for the pump?
Old Jul 22, 2008 | 09:47 PM
locash's Avatar
Default Re: Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">What size wiring are you using for the pump? </TD></TR></TABLE>
20 ga will work, right?
Old Jul 23, 2008 | 04:11 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16b18 &raquo;</TD></TR><TR><TD CLASS="quote">I only brought this topic up because I've been having a heck of a time with this new pump and I'm running out of possible causes.</TD></TR></TABLE>
where is it mounted in relation to fuel level?
Old Jul 23, 2008 | 07:06 AM
b16b18's Avatar
Default Re:
I'm using the Painless Wiring relay kit which draws directly from the battery and a 10 gauge ground to the chassis.
The pump is mounted lower than the fuel cell. With 10AN inlet and 8AN outlet lines, and a 6AN return.
I've been thinking it's an electrical issue also which is why I was asking if mounting the pump to the chassis could affect the grounds. Just don't know what else to check..
Old Jul 23, 2008 | 08:43 AM
redboost10's Avatar
have you checked your fuel filter
Old Jul 23, 2008 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16b18 &raquo;</TD></TR><TR><TD CLASS="quote">I'm using the Painless Wiring relay kit which draws directly from the battery and a 10 gauge ground to the chassis.</TD></TR></TABLE>
What size power wire?
Old Jul 23, 2008 | 05:33 PM
b16b18's Avatar
Default Re:
It's a brand new filter. The one that Aero says to use with this pump.
12 ga wire from the battery to the relay and to the pump. The factory wire then goes to the relay.
When I turn the ignition ON, you can hear the pump turn although it sounds like its struggling and it doesn't build much pressure, just a few psi registered on the gauge at the fuel rail.
Old Jul 23, 2008 | 06:13 PM
misfertech's Avatar
Mine would get hot and start to stall my car like if it was running out of gas, even tho I knew it had plenty....Seems when it gets hot it does not want to pump fuel.. You need a voltage controller. It becomes very annoying having to wait 15 minutes for the pump to cool down enough to build pressure again....
Old Jul 24, 2008 | 04:27 AM
Default Re: (misfertech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfertech &raquo;</TD></TR><TR><TD CLASS="quote">Mine would get hot and start to stall my car like if it was running out of gas, even tho I knew it had plenty....Seems when it gets hot it does not want to pump fuel.. You need a voltage controller. It becomes very annoying having to wait 15 minutes for the pump to cool down enough to build pressure again....</TD></TR></TABLE>
I don't think he needs the controller. I ran both the A1000 and the eliminator in my street car for long periods of time with no issues.
Your wiring size sounds good. Check to make sure your lines are not pinched somewhere under the car. Or that you have something clogging/blocking your sump/feed hole in the tank.
Old Jul 24, 2008 | 12:07 PM
b16b18's Avatar
Default Re:
Aero's installation instructions say to use 10 ga from the battery source to the pump. The relay kit came with 12 ga for that wire.
By lines pinched do you mean wires or fuel lines? The fuel lines are definetly not pinched. I was going to rewire the switched ign wire that goes to the under dash fuse box. I was having an issue at first where the under dash fuse was blowing as soon as I turned the ign ON. Maybe there's some stripped wiring or something under there going on? It's pretty much all factory wiring still under the dash.
Old Jul 26, 2008 | 07:17 AM
B18c1turboedEK's Avatar
You need to get the power for the Alt, the battery might not be sending the right voltage back there at all times, i had that problem.
Old Jul 31, 2008 | 02:56 AM
1FSTCPE's Avatar
check your sump.My car did the same thing losing fp untill i got a better sump.The car would only keep fp with a full tank of gas.
redboost10
Jul 5, 2006 07:40 PM
ezark
Jun 10, 2006 12:41 PM
hovic
Mar 12, 2006 03:43 PM
CiViC SiR
Dec 21, 2005 09:03 PM
