So i went back to the track last night...
Old Jul 20, 2008 | 11:23 AM
dustin528's Avatar
Default So i went back to the track last night...
Well like it says, i got my car back together and took it to the track last night. It is a stock jdm gsr motor in my delsol with full race manifold, 57 trim .60/.63 a/r turbonetics. I'm running 9 psi of boost. sadly all we have in AR is 1000 ft. I trapped 105 consistently every run! I didn't have my 2 step working, cause i didn't have a laptop so i didn't want to be stuck with it at to low of a rpm. So i bogged every run except my last two, and i hotlapped the last 4 runs. The time below is my last run and fastest of the night. I'm am spinning through 3rd on my 23 x 7.5 m&h slicks. I ran about 3 weeks ago when it was running way richer, so it was making less power, and i ran a 10.35 @ 103. Traction wasn't as much of an issue that night. I was wondering what other guys are running in the 1/4 with these kind of times. and also what kind of power you guys are making.
1.89 60 ft
5.43 330 ft
8.22 1/8 @ 88 mph
10.42 1000 ft @ 105 mph
Old Jul 20, 2008 | 11:44 AM
SovXietday's Avatar
Default Re: So i went back to the track last night... (dustin528)
I read that and was like 10.4 @ 105 WTF!?
Then I saw the missing 320.
Looks good man.
Old Jul 22, 2008 | 09:36 AM
dustin528's Avatar
so is anyone running these kind of times in the 1000 ft with that mph??
if so what kind of power are yall making?
Old Jul 22, 2008 | 09:22 PM
Outkast95LS's Avatar
Default Re: (dustin528)
well, at about 285whp, i was running a 12.8@110mph. This was with a 1.8 60', 8.292@87.738 1/8th mil, and running 10.799 at the 1000' mark.
Old Jul 22, 2008 | 09:30 PM
boostin94ex's Avatar
where is there a 1000 track in arkansas all i knew about was the 1/8 mile at centerville
Old Jul 22, 2008 | 10:03 PM
juda7's Avatar
Old Jul 23, 2008 | 09:08 AM
dustin528's Avatar
Default Re: (boostin94ex)
centervill is 1000 ft.
Old Jul 23, 2008 | 09:10 AM
dustin528's Avatar
Default Re: So i went back to the track last night... (juda7)
hey are those the 23 inch m&h's or are they bigger? I'm getting ready to buy some 24.5's i think. What was your 1/8 mile time and 1000 ft time on that run? also 60 ft, and mph's??
Old Jul 23, 2008 | 04:02 PM
kings_blend's Avatar
what song is in that video?
Old Jul 24, 2008 | 09:44 AM
dustin528's Avatar
anyone else??
Old Jul 24, 2008 | 10:02 AM
HiProfile's Avatar
Well at 107mph, you're going ~157fps, so it would be another 2 seconds to get to 1320 at 107mph. A little less since you're accellerating. So about 12.4-12.1 in the quarter.
Old Jul 24, 2008 | 11:35 AM
legomytego's Avatar
damn your good ^ i suck at math and 12s dont sound bad at all then
Old Jul 24, 2008 | 10:12 PM
juda7's Avatar
MH 24.5 on Lenso's
Old Jul 24, 2008 | 10:17 PM
juda7's Avatar
Default Re: (kings_blend)
Feels Like July-We Found A Home.
Old Jul 27, 2008 | 02:13 PM
dustin528's Avatar
Default Re: (juda7)
nice thanks for those timeslips, that helps me. I wish the slips would show the 1000 ft mph.
Old Jul 27, 2008 | 03:22 PM
Bugermass's Avatar
You need to do a thrid gear burnout and get the slick down around 8 PSI, and you shouldn't spin anymore.. From looking at the vid your not getting enough heat into the tires. Just go into the water, do a quick spin to get water all the way around, roll forward , put it in 3rd gear rev high then let her rip.. It should only take about 4 seconds or so.. Basically once you go from light smoke to thick smoke stop.. You want to stop doing your burnout right when your tires start making thick smoke. If you burn out too long past the thick smoke stage you will overheat the tires and it won't be as good. Try that and let us know what you run..
Old Jul 28, 2008 | 08:13 PM
o ok i was told centerville was 1/8 mile my bad
Old Jul 28, 2008 | 09:28 PM
TurbodTegSfaria's Avatar
i ran 12.5 @118 with 10lbs ebay turbo kit few years strong .ran 12.8 with 15lbs.. also with 205/55 nitto drag rads
Old Jul 30, 2008 | 09:20 AM
dustin528's Avatar
Default Re: (Bugermass)
Wrong car man. that's not mine, it's the other guys in this thread. my problem is the size slick i have for my power. I'm going to be at memphis motorsports park this weekend for the traction optional drag/drift event. I can't wait! Maybe there will be some people from memphis that are on here there!
I went back to centerville again last saturday and it was so hot! I was still trapping 105 to 106. It was 88 degrees at the track. It warmed up more after i got there. even at 11 at night it was still that hot.
aaronISthrowed
Feb 15, 2007 06:46 PM
ITR.#1446
Mar 28, 2004 03:57 PM
Nextelbuddy
23
Oct 4, 2003 02:46 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
pagong
May 9, 2002 11:36 PM
