Adding 4 wire O2 to a 92 CX? Do any wires need to be run?
Old Jul 20, 2008 | 09:32 AM
T-RO's Avatar
Default Adding 4 wire O2 to a 92 CX? Do any wires need to be run?
I swapped a JDM SOHC D15B into a 92 Civic CX. I used an EX engine harness with a P28 ECU. Do I have to add or swap any wires for my 4 wire O2 to work correctly now since it was previously 1 wire (or whatever).
Thanks
Old Jul 24, 2008 | 01:06 PM
T-RO's Avatar
bump
Old Jul 24, 2008 | 01:16 PM
94EG8's Avatar
Seagull Management
Default Re: Adding 4 wire O2 to a 92 CX? Do any wires need to be run? (T-RO)
you need to run 3 wires for the O2 sensor, easiest way is to just go to a junkyard and buy a '94 - '95 DX/LX engine harness. Do not get a '92 - '93 harness, you will not have a plug for the map sensor if you do.
Old Jul 29, 2008 | 01:31 PM
T-RO's Avatar
I am already using an EX engine harness. Does anything need to be run from the shock tower plugs to the ECU?
Old Jul 31, 2008 | 05:07 AM
94EG8's Avatar
Seagull Management
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">I am already using an EX engine harness. Does anything need to be run from the shock tower plugs to the ECU?</TD></TR></TABLE>
Sorry, i didn't notice you said you used an EX harness, no wires need to be run, they are already run from the ECU to the shocktower plug.
Old Aug 6, 2008 | 03:01 PM
T-RO's Avatar
Cool thanks... trying to troubleshoot a poor running car.
Old Aug 6, 2008 | 03:10 PM
94EG8's Avatar
Seagull Management
Default Re: (T-RO)
Did you add the purge solenoid on the back of the intake? Is it timed right? dented oil pan?
chevmaro
11
Jul 11, 2011 09:23 PM
scythe88
Jan 17, 2010 05:54 AM
peiku
Nov 27, 2006 05:07 AM
2DoorBandit
Mar 27, 2006 05:36 AM
DevineCRX
Jul 18, 2002 07:31 AM
