need help brakes went out on 93 civic si
my brakes went out, this is a non abs civic. i have a very small amount of petal pressure. i have replaced the master cylinder with a new one. cant find leaks in brake lines. i'm wondering where to go next.
thanks Tommy
thanks Tommy
Re: need help brakes went out on 93 civic si (notstreetlegal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstreetlegal »</TD></TR><TR><TD CLASS="quote">my brakes went out, this is a non abs civic. i have a very small amount of petal pressure. i have replaced the master cylinder with a new one. cant find leaks in brake lines. i'm wondering where to go next.
thanks Tommy
did you bleed the brakes after install and what order did you do them in?
also is the booster bad?
thanks Tommy
Re: need help brakes went out on 93 civic si (philosofy1)
i did bleed them before and after and in the correct order according to my chilton manual. ill check out the brake booster.
http://hondatech.info/downloads/Auto/Manuals/
Down load the manual and read the brake trouble shooting tables.
