ot need help getting the horn to work on the itr
Old Jul 19, 2008 | 07:15 PM
mugenr#1011's Avatar
Default ot need help getting the horn to work on the itr
so ill try to make it short, the horn hasnt been working for awhile. i have an fg-360 but everything is wired up but no luck. i tried to find the harness for it but it looks like someone cut it off. any help would be greatly appreciated as i am stuck on this one bolt ons and general work on the itr is easy but i suck at wiring.. thanks
Old Jul 19, 2008 | 07:20 PM
Todd00's Avatar
I said I don't want a title!
Default Re: ot need help getting the horn to work on the itr (mugenr#1011)
Been a while since I played with an aftermarket wheel in a DC2, but IIRC you will need to wire up the horn button, but you'll also need to have a contact 'arm' touching constantly on the back of the hub.
With the old EF's and such, it was a simple plug and play. But with the newer cars (DC2), it is a bit more difficult. I am not sure if anyone ever came up with a kit or not.
Old Jul 19, 2008 | 07:27 PM
thanks todd00....well the fg is completly wired up. anyone have any diagrams or some helpful info?
Old Jul 19, 2008 | 07:34 PM
BlueIntegraBoy's Avatar
Did you test that the horn works? Hook it straight up to the battery.
Old Jul 19, 2008 | 07:50 PM
Default Re: ot need help getting the horn to work on the itr (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Did you test that the horn works? Hook it straight up to the battery.</TD></TR></TABLE> do you mean to test the relay? sorry ive never heard of this method before.
Old Jul 19, 2008 | 08:01 PM
Spids5's Avatar
Don't judge or question
Try this thread, it has the contact arm Todd00 mentioned.
https://honda-tech.com/zerothread?id=1887852
Old Jul 19, 2008 | 08:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenr#1011 &raquo;</TD></TR><TR><TD CLASS="quote"> do you mean to test the relay? sorry ive never heard of this method before. </TD></TR></TABLE>
Remove the horn from the bumper and use two wires, pos and neg. OR run two wires from the battery to the horn.
When I went to hook up the horn on my JDM ITR non-SRS wheel in my old hatch, the horn didn't work even though the wiring was correct (relay clicked when I pressed the button). The horn was actually bad, so I replaced it.
Old Jul 19, 2008 | 08:31 PM
thanks for the help guys....i put a new horn housing in so we will see
Old Jul 21, 2008 | 04:55 PM
ok just an update i went to a local dealer today. the tech who i always have work on my car, attached a wire harness to the horn. said that the horn beeped but not from the horn buttons on the fg-360...he said everthing seems to be wired up right and it needs a ground. but today at home i took the wheel off and it seems the mugen hub has a contact wire welded to the front but not the back.
how can i make a contact for the back? will using wires from the stock wheel work?
thanks... i need a
guamboas
Feb 27, 2009 02:12 AM
Teknic73
Feb 19, 2004 07:55 PM
jdmspoonitr
Jul 31, 2003 02:14 PM
Lei Siew Long
12
Jan 25, 2003 03:29 PM
