need help wiring horn to momo wheel
had my momo wheel for about 4 years and never bothered to wire the horn. what, i'm planning to do is, find the horn wire from the airbag harness with a test light and use that to make contact to the hub of the momo wheel.
but, i'm not sure if i have the right wire because when it makes contact with the hub and the button is hooked up, when the connection is made, the only thing i hear is a clicking noise everytime the horn button was pressed.
here is a link to the method i'm following:
http://www.urbanasian.com/pcin05.php
Re: need help wiring horn to momo wheel (boostedeg6)
ok, the january 2003 sport compact car had a little explanation on how they did it on their project eg, the wire they used from the airbag harness was the upper left hand wire on the plug (with the keys that only let you plug it in one way facing down), someone can probably scan it.
Re: need help wiring horn to momo wheel (cplessl)
a scan or a little more help would be great.
are you referring to this harness?
Re: need help wiring horn to momo wheel (edrop27)
IM EG6Si, he knows the exact part you need to do this very easily, there is a stock part. he helped me out with mine and I couldn't be happier...VERY EASY!
Re: need help wiring horn to momo wheel (RSZero1)
thanks edrop for the bump and thanks for the info rszero. i'll IM him now.
Re: need help wiring horn to momo wheel (Typel2)
eg6si was kind enough to provide the link and pictures necessary for this task.
here it is:
https://honda-tech.com/zerothread?id=273474
here it is:
crdcz03
09-10-2020 09:23 PM
HYBRIDHATCH92
09-07-2002 07:10 AM
