b16 obd1 swap. need to install resistor pack for DSM injectors. HELP
Old Jul 19, 2008 | 03:20 AM
dc2doi's Avatar
Default b16 obd1 swap. need to install resistor pack for DSM injectors. HELP
Installing some DSM 450cc injectors for b16 thats in the crx.
The b16 is OBD1. So I had a custom wiring harness made and used a jumper harness for the ECU.
What I want to know is how can I install a resistor pack for the DSM injectors.
I was wondering if I can do something like this.
Cut where all the 4 wires that goes into the injectors, solder it up together and wire it to that one single one which I believe is a yellow/black wire.
Then solder the other ends on the injectors to the red wires on the resistor pack.
I drew a picture to show what I am talking about. Will it work like this?
Old Jul 19, 2008 | 06:00 AM
90_EX_Civic's Avatar
Default Re: b16 obd1 swap. need to install resistor pack for DSM injectors. HELP (dc2doi)
here's a good write up, sorry, hope i don't get in trouble for linking to other site,
http://homemadeturbo.com/tech_....html
Old Jul 19, 2008 | 07:19 PM
dc2doi's Avatar
I've seen all of the write up but nothing about what I'm trying to do.
Can anyone help?
Old Jul 19, 2008 | 07:56 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: (dc2doi)
Are you running an OBD1 computer? If so, you are going to need to leave it stock (as far as injector wiring) Just follow a DPFI to MPFI guide and you should be on your way.
Old Jul 21, 2008 | 12:00 AM
dc2doi's Avatar
Not exactly sure what DPFI to MPFI is.
Wiring harness right now is custom for the b16a with a OBD1 ECU thru a obd0-obd1 jumper harness.
Old Jul 22, 2008 | 12:56 AM
dc2doi's Avatar
Bump. Anyone?
Old Jul 22, 2008 | 01:21 AM
ef92b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2doi &raquo;</TD></TR><TR><TD CLASS="quote">Installing some DSM 450cc injectors for b16 thats in the crx.
YES.
you don't have to solder all together those 4 YLW/BLK wires which you just cut/spliced off from each injector. just take one of them(insulate the rest) since they all come from one source(it's the same wire that goes to ECU pin A25, B1, Main Relay, O2, IACV) then do the injectors to the resistor pack rerouting... just like what you've drawn. .
Modified by ef92b at 1:32 PM 7/22/2008
Old Jul 22, 2008 | 01:30 AM
ef92b's Avatar
Default Re: (Tonio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonio &raquo;</TD></TR><TR><TD CLASS="quote">Are you running an OBD1 computer? If so, you are going to need to leave it stock (as far as injector wiring) Just follow a DPFI to MPFI guide and you should be on your way.</TD></TR></TABLE>
depends on what type of injectors you intend to use. Low impedance ones require a resistor box. high impedance = no resistor box req'd.
dc2doi, are your DSM injectors low impedance ones ( 2-5ohms)?
Old Aug 24, 2009 | 04:50 PM
schock3's Avatar
I just bought some LOW IMPEDANCE 450cc injectors and im doing the OBD0 to OBD1 conversion. do i use the resistor box that is already in there?
93grayeg
Jan 9, 2010 02:19 AM
vtechrex
Jan 22, 2006 03:17 PM
jDMJeRk
Apr 30, 2004 03:08 AM
Timmah!!
May 20, 2003 07:47 PM
untitled
Mar 19, 2003 11:00 AM
