DSM 450cc; bigger injectors or would will I be safe....
Old 04-29-2004, 11:02 PM
jDMJeRk's Avatar
Default DSM 450cc; bigger injectors or would will I be safe....
I had boughtin some bluetops a few months ago cause I got a good deal on them....Im thinking now I should just buy some 880s or so just to be safe. Ive got a b16 project that Im working on and I have a resistor box so I though the 450cc were a great deal. I want to make 300-400whp on about 10-15psi....Should I sell these or keep them? Im running a obd0 engine harness and converting to obd1 how hard would it be to wire up the other type of injectors....(not sure if i have peak and hold or saturated now)
Thanks!
Old 04-30-2004, 12:31 AM
jDMJeRk's Avatar
Default Re: DSM 450cc; bigger injectors or would will I be safe.... (jdmjerk)
bump for the late nighters
Old 04-30-2004, 12:39 AM
ndogg's Avatar
get bigger ones. the 450 are questionable at 300hp. the 450's are low impedence, so if you get some big 880's from precision, it will be a drop in install.
Old 04-30-2004, 01:04 AM
jDMJeRk's Avatar
Default Re: DSM 450cc; bigger injectors or would will I be safe.... (ndogg)
I could still use my resistor box and ****? Where did you get yours ndogg; thats why I came up with the idea of getting new ones....Im scared that my motor isnt going to even keep up with yours.... :*(
Old 04-30-2004, 01:32 AM
quik sol's Avatar
from what I understand is with precision and rc injectors you dont need resistor boxes....but thats what I have read...nothing set in stone
Old 04-30-2004, 01:48 AM
ndogg's Avatar
i got mine from http://www.import-palace.com and you can use your resistor box with them.
as for quik sols comment, thats only if you get the HI impedence version. precision doesn't make one that big. since you already have the resistor box, there is no real reason to get the hi impedence ones.
Old 04-30-2004, 03:08 AM
blown_LS's Avatar
There is few dsm guys making 300+ awhp with stock injectors. So basically they max out at 300 whp from what i have seen.
Just my 02.
mortificationrock
06-10-2007 09:05 PM
drSquish
01-19-2006 01:54 PM
b16hatche
10-24-2005 08:03 PM
NOTENOUGHBOOST
02-15-2004 09:23 AM
sivik2nr
06-11-2003 09:59 PM
Quick Reply: DSM 450cc; bigger injectors or would will I be safe....
