cruise control in em1
Old Jul 18, 2008 | 04:48 PM
mugen si's Avatar
Default cruise control in em1
a couple years ago i bought a 00 Si. it came with an aftermarket steering wheel and thus did not come with the cruise control switch. the horn is not hooked up in the aftermarket steering wheel. I took the steering column cover off to inspect to see if there is any connectors that may be for the cruise switch.(there is a yellow and a green wire in a yellow shrink tube that has been snipped)--->is this for the horn? also there is light grey, blue, and brown wires that lead into a male plugin. the pug in is black(dont kno if someone has altered this or not). there is also no clockspring on this car, just these two sets of wires that i have described. well the black plug in did not fit in the cruise switch so i altered it to somewhat fit. went for a test drive and nothing. the main dash mounted cruise button lights up but nothing wrks after that....no cruise. can someone tell me if the blue, light grey, and brown wires are the cruise control wires. and any other help would be great! thanx.
Old Jul 18, 2008 | 05:00 PM
mugen si's Avatar
Default Re: cruise control in em1 (mugen si)
also wanted to add that all fuses are good and also evrything looks fine under the hood/ do i need to hook up my horn button to get the cruise the function or no? i also have a srs light on the dash because i have no airbag with this wheel, could this be a problem too?
Modified by mugen si at 8:21 PM 7/18/2008
Old Jul 18, 2008 | 05:11 PM
94EG8's Avatar
Seagull Management
anything in yellow loom or shrink tubing is pretty much reserved for airbags. light green/red and light green/black are the wire colors you should be looking for in the steering column. Horn wire should be blue.
Old Jul 18, 2008 | 06:07 PM
mugen si's Avatar
Default Re: (94EG8)
well i just pulled off steering wheel and tucked in the hub was a black wire. could this be a ground for the horn? also if the horn wire would be blue, why would it be linked in to the same plug in as the brown and light grey wires are? thanx.
Old Jul 18, 2008 | 06:26 PM
94EG8's Avatar
Seagull Management
Default Re: (mugen si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen si &raquo;</TD></TR><TR><TD CLASS="quote">well i just pulled off steering wheel and tucked in the hub was a black wire. could this be a ground for the horn? also if the horn wire would be blue, why would it be linked in to the same plug in as the brown and light grey wires are? thanx. </TD></TR></TABLE>
Thats what i don't get, i have the 2000 Si cruise control wiring diagram right in front of me, but it doesn't seem to be matching up to the wires you have, although it looks like the horn starts out grey, then turns to blue, goes throught cable reel that you probably don't have, and then turns black. I'm not seeing a light brown wire anywhere near the steering column.
Old Jul 19, 2008 | 02:24 PM
mugen si's Avatar
Default Re: (94EG8)
i know, its messed up. i also have the wiring diagram, but cant figure it out. the male plug in has 4 openings of which 3 are only live wires. i notice the cruise switch has 4 prongs inside the yellow female plug. after looking at the wire diagram this seems to be somewhat correct. it shows 3 live wires(blue light grey and brown) being plugged in to the switch, which has 4 prongs(one prong plugs intothe blank/dead spot). im by no means an electrician but would like to figure this out soimewhat. ive heard the horn needs to be hooked up?---&gt;do i need to wire up my horn button to get the cruise to work?...maybe it acts as a ground??
Modified by mugen si at 5:56 PM 7/19/2008
Old Jul 19, 2008 | 02:55 PM
mugen si's Avatar
after looking more at my manual. im pretty sure that the 4p connector with the 3 live wires is actually the cable reel sub harness 3P connector. so two of those wires has to be for the cruise switch and the other may be for the horn(blue)?? haha im just throwing some stuff out there. also just went back out and looked at the 3 live wires that i have been talking about, and the brown wire is not brown, it seems to be an orangish color.
Old Jul 19, 2008 | 03:17 PM
94EG8's Avatar
Seagull Management
The horn wire is supposed to be blue on the wheel side of the cable reel. I'm not seening any orange colored wires at all for the cruise control circuit. Honestly i'm as confused as you are about this, but perhaps if you could take some pictures of the wires in question it would help.
Old Jul 19, 2008 | 05:55 PM
mugen si's Avatar
Default Re: (94EG8)
ok ill try to get some pics loaded tomorrow. thanx for all the help so far.
accord99power
Mar 18, 2013 05:12 PM
Broyo
Dec 7, 2011 02:45 PM
moorekh
Sep 12, 2010 07:56 PM
DaveSi677
Dec 14, 2005 04:15 PM
nurvcom..
Oct 12, 2005 02:59 PM
