Quick question about sizing piston rings up for a rebuild...
Old Jul 18, 2008 | 12:08 PM
24TEN's Avatar
PHANTOM MENACE
Default Quick question about sizing piston rings up for a rebuild...
I'm currently rebuilding my stock motor and I'm sizing up the rings right now. I was wondering, min/max ring end gap is .006-.024 I believe and my question is should I be aiming for the big end of the gap? I was thinking I should shoot for the smaller end of .006 so I'd have the optimum seal per the minimum gap but then I thought, doesn't the ring expand (like all other metals) when it gets heated up? So I was thinking that by going for the bigger gap, I'd have a better "buffer" in case the metal expands too much. Anyone have any knowledge (first hand preferred) about the correct method to size up the ring end gap? Keep in mind, it's a stock rebuild. I'm not going for power increase, turbo, etc. The only thing not stock is it's overbored .5mm due to a cylinder not being round at one spot.
Old Jul 19, 2008 | 02:28 AM
moonglow 600-piece's Avatar
Default Re: Quick question about sizing piston rings up for a rebuild... (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">I'm currently rebuilding my stock motor and I'm sizing up the rings right now. I was wondering, min/max ring end gap is .006-.024 I believe and my question is should I be aiming for the big end of the gap? I was thinking I should shoot for the smaller end of .006 so I'd have the optimum seal per the minimum gap but then I thought, doesn't the ring expand (like all other metals) when it gets heated up? So I was thinking that by going for the bigger gap, I'd have a better "buffer" in case the metal expands too much. Anyone have any knowledge (first hand preferred) about the correct method to size up the ring end gap? Keep in mind, it's a stock rebuild. I'm not going for power increase, turbo, etc. The only thing not stock is it's overbored .5mm due to a cylinder not being round at one spot.</TD></TR></TABLE>
Hey, they say: the bigger the ring, the louder she sings.
Old Jul 19, 2008 | 06:50 AM
Lubo_25's Avatar
what motor is this for??get an oem service manual, but this is what I do for my ring sizings...
your average is going to be .015"(.006+.024/2) so what i usually do after making my averages i add .001"-.002" accordingly
for example my CP rings are all very close to min. spec of .016" but I will be filing them to .018" for the primaries...
follow your oem manual and you dont want to shoot for the minimum stay around the middle and you should be good to go...AND! dont forget to file them inwards and stone the rings as well
Old Jul 19, 2008 | 09:34 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Quick question about sizing piston rings up for a rebuild... (Lubo_25)
That's actually where I'm at right now on the first set, a few thousandths under max end gap. I didn't think the motor itself mattered since it's kinda based on technique but since you ask, it's just a D15B8.
I was going by the Chilton's manual and compared the specs to the FSM and guess what? Chilton's listed the end gap as stated above for min/max while the FSM states, .006-.012 with a service limit of .024. So pretty much, I filed them past the ideal gap specs
Off to the dealer I go to order one set of rings for one damn piston
Modified by 24TEN at 10:39 AM 7/19/2008
Old Jul 20, 2008 | 04:33 PM
Lubo_25's Avatar
the reason I asked what motor it was for because you always need to double check the service manual for the motor before making any assumptions...just follow the honda manuals those are my bibles...never trust third hand publishing
Spoon84
Jul 19, 2010 01:34 PM
KURUPTinc
Aug 25, 2007 12:24 PM
KooK
Feb 4, 2006 09:08 PM
djtony5
Nov 9, 2005 08:28 AM
gramentz
Jun 5, 2005 08:07 AM
