One Injector Does not fire! help!
Old Jul 18, 2008 | 10:08 AM
RxglassJAw's Avatar
Default One Injector Does not fire! help!
Number 4 injector wire does not fire no matter which stock injector i swap there. Although when i plugged one of my 450 dsm peak and hold injectors in it sounded like it was pumping. Any ideas?
Old Jul 18, 2008 | 10:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: One Injector Does not fire! help! (RxglassJAw)
did you noid light it yet? is there 12v at the yellow/ black wire?
Old Jul 18, 2008 | 10:28 AM
RxglassJAw's Avatar
Default Re: One Injector Does not fire! help! (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">did you noid light it yet? is there 12v at the yellow/ black wire?</TD></TR></TABLE>
calling around to see if i can find one. No luck yet. Any suggestions? I'll grab a voltmeter now and see what i come up with.
Old Jul 18, 2008 | 11:05 AM
RxglassJAw's Avatar
Just checked voltage on the yellow/black wire yes it has 12volts. Checked the other clips as well. exact same.
Old Jul 18, 2008 | 11:16 AM
Mr. Badwrench
Default Re: (RxglassJAw)
ok the noid light will tell you if the ecu is pulsing that injector. it is too fast for a volt meter to react. you need the led in a noid light because a test light is too slow also.
do that and see if it is "noiding" and go from there.
Old Jul 18, 2008 | 11:30 AM
RxglassJAw's Avatar
Default Re: (boostedcivicsir)
gotcha. still looking for a noid light. Also i swapped computers with someone just to see if it was that... same issue.
Old Jul 18, 2008 | 11:31 AM
RyanA's Avatar
Also, if no noid light, you can go to Radio Shack and get a 12 volt LED or get an LED and the appropriate sized resistor. An LED will react quickly enough and you will only have a couple bucks in the setup. You'll probably want to tin the wire ends so you can push them into the injector clip easier.
Ryan
Old Jul 18, 2008 | 11:35 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RxglassJAw &raquo;</TD></TR><TR><TD CLASS="quote">gotcha. still looking for a noid light. Also i swapped computers with someone just to see if it was that... same issue. </TD></TR></TABLE>
unless you have 2 ecu's with bad drivers, now you need to check continuity from the not yellow/black wire back to the ecu and make sure it is not open or shorted.
Old Jul 18, 2008 | 01:04 PM
RxglassJAw's Avatar
hooked up 12v LED. Flashed brightly...
Old Jul 18, 2008 | 01:32 PM
RxglassJAw's Avatar
Since i'm getting a signal to the injector and all the wiring is in great shape and i'm getting spark but just no fuel is coming out do you think it's a tuning issue? I have intake, headers, full exhaust, jdm itr pistons which is more compression, 402 crower cams, cam gears, and skunk2 intake manifold. stock never touched ecu. just a thought sorry if it's a dumb one, but i'm pretty confused.
Old Jul 18, 2008 | 03:06 PM
Mr. Badwrench
swap #3 #4 injector, see if the problem moves one cylinder over. its kinda hard to do this with a keyboard. he hee.
Old Jul 18, 2008 | 03:12 PM
RxglassJAw's Avatar
i just switched 4 and 2 and no difference. do you still want me to switch 3 and 4?
Old Jul 18, 2008 | 03:53 PM
RyanA's Avatar
OK, you have moved the injectors from what I understand, right? Have you verified you have compression on that cylinder???
Old Jul 18, 2008 | 04:10 PM
RxglassJAw's Avatar
Default Re: (RyanA)
no but it's been freshly rebuilt. brand new OEM pistons and rings and the head was completely redone including a multi angle valve job... all i had to do was put the head on the block... pretty sure the compression is good. i can definitely check though.
When i pulled the injector out the tip was dry unlike all the other three... were wet with fuel. every time i switch injectors that one is always dry(moved it many times). Spark plug is dry also.
Old Jul 18, 2008 | 07:10 PM
RyanA's Avatar
Any chance there is an obstruction at the opening of the fuel rail for that cylinder??? That or low fuel pressure are the only 2 things I can think of that would cause this. Well, those and low voltage to that injector...
Old Jul 18, 2008 | 07:32 PM
gsrhatch2356's Avatar
Default Re: (RyanA)
if the light flashes when backprobed then more then likely the electrical part is good but your saying that no matter what the injector is always dry so it has got to be at the connector make sure you are getting good contact cause it really dont make sense. you know the injector is good cause you switched it, you know you are getting a pulse so the problem is at the connection.
Old Jul 18, 2008 | 08:16 PM
RxglassJAw's Avatar
Default Re: (gsrhatch2356)
i've got a fuel pressure regulator and a gauge... i bumped it up a little HIGH to 40psi. No obstructions at all i know that.
Anything to improve connection there? It seems pretty straight forward. Also i tried moving it around as much as possible when i had the car running to see if i could make a difference. No luck.
Should i grab another clip from the junkyard?
Old Jul 18, 2008 | 08:28 PM
RxglassJAw's Avatar
something just came to me... i should just cut three and four clips and switch them... lol.
Old Jul 19, 2008 | 04:30 AM
RxglassJAw's Avatar
Off to the Pittsburgh honda meet. hope to figure out connection issue sunday. Thanks for all the help so far!
Old Jul 19, 2008 | 04:55 AM
RyanA's Avatar
I'd find an EXTRA connector and swap it on there. No need to move the problem; you are trying to get rid of the problem...
Old Jul 20, 2008 | 09:50 AM
RxglassJAw's Avatar
clip is in great working order. i didn't even use foil when i plugged in my LED. Squeezed together the connections inside the clip. Very tight fit.
Old Jul 20, 2008 | 10:32 AM
well there has to be something wrong with one of the test then cause if the led flashes then the injector should open and if you are switching around inj and are for sure that one is staying dry then something is wrong there and you just need to isolate it and go from there. gl
Old Jul 20, 2008 | 10:57 AM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: (RyanA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanA &raquo;</TD></TR><TR><TD CLASS="quote">Any chance there is an obstruction at the... fuel rail for that cylinder??? That or low fuel pressure [for that cylinder]...</TD></TR></TABLE>
+2
Sorry for this meaningless post, but nobody responded to the above...
I'm thinking the same way as RyanA!
Old Jul 20, 2008 | 11:10 AM
RxglassJAw's Avatar
Default Re: (BlackDeuceCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 &raquo;</TD></TR><TR><TD CLASS="quote">well there has to be something wrong with one of the test then cause if the led flashes then the injector should open and if you are switching around inj and are for sure that one is staying dry then something is wrong there and you just need to isolate it and go from there. gl</TD></TR></TABLE>
well i removed the fuel rail and took out the injectors. perfectly clear. lots of fuel coming out the back of the fpr... can't figure out what test is wrong. 12 volts, pulse, dry injector, new plugs, spark.
Old Jul 20, 2008 | 12:00 PM
RyanA's Avatar
whats your fuel pressure?
