customer car question
Old Jul 18, 2008 | 07:11 AM
rdssk8rcs1's Avatar
Default customer car question
A kid came in with a 93 ls block with a 99 type r head bolted to it. It leaks oil all over the place. So I have two questions will this combination even work? And if it will what head gasket should be used. I have never eve. Heard of a ls/vtec combination like this.
Thanks in advance for any insight
Old Jul 18, 2008 | 07:30 AM
hatchling37's Avatar
Default Re: customer car question (rdssk8rcs1)
They should bolt up fine if the dowel holes are drilled out properly. I'm not positive on the gasket, I read something recently on what one to use, I'll try and find it.
Old Jul 18, 2008 | 09:48 AM
rdssk8rcs1's Avatar
Default Re: customer car question (hatchling37)
Thanks for the input
Old Jul 21, 2008 | 11:03 AM
inspyral's Avatar
It works, and you can either drill out the head to accept the dowels relocated to the rear, or you can use aftermarket LS/VTEC dowels that will drop right in. You can use either an LS head gasket or a B series VTEC, but the LS gasket has one of its rivets on the head surface, so it needs to be removed. Golden Eagle, who make and sell LS/VTEC kits, recommend using a VTEC gasket because of this, and their views are documented here:
https://honda-tech.com/zerothread?id=2235725
As for the leaks you're seeing, it's entirely possible that the head gasket was installed upside down, or the head and block were machined enough to the point where the dowels are too tall and keeping the head from fully contacting the block.
88.REX
Nov 17, 2009 08:46 AM
blk90teg
Feb 14, 2007 08:53 PM
civicswap
Jun 4, 2005 06:44 PM
tunedek
Feb 26, 2005 12:01 PM
tysir
Aug 20, 2001 07:27 PM
