what are these features on hondata
Old Jul 17, 2008 | 10:32 PM
cehcivic15's Avatar
Default what are these features on hondata
full throttle shift, launch control, and what is a wideband o2?...not new to hondas, just new to the aftermarket world
Old Jul 18, 2008 | 03:13 AM
DaveF's Avatar
Default Re: what are these features on hondata (cehcivic15)
google ?
Old Jul 18, 2008 | 05:55 AM
slow96coupe's Avatar
I heart google
Its your friend.
Old Jul 18, 2008 | 06:09 AM
ralph11sec's Avatar
Default Re: (slow96coupe)
yahoo?
Old Jul 18, 2008 | 06:59 AM
Default Re: (ralph11sec)
google > Yahoo
anyday
Old Jul 18, 2008 | 09:17 AM
sanimalp's Avatar
$cat /dev/urandom
launch control holds your car at a certain rpm, so if you set it right, it will allow you to leave the line without bogging, but also without doing a burnout. The idea is that you will get more consistent drag race launches with launch control.
full throttle shift reads the signal from the clutch switch, so you can leave the gas buried while shifting, the clutch switch activates a minor rpm drop, so you can shift and stay in boost/powerband, etc.. when the clutch switch goes off, the throttle pedal takes over again. the idea here is that you won't see as much of a delay in your shifting process. This feature is also commonly called "no lift to shift" or "expensive" (i made up that last bit..).
a wideband o2 is a special highly sensitive air/fuel ratio sensor. most cars come with what is usually referred to as a narrowband o2 sensor, which basically says "rich" or "lean". the point of a wideband is that it allows you to much more accurately determine the air/fuel ratio of the engine, which allows you or a tuner to optimize the performance of your particulare engine setup. the wideband effectively says "how rich" or "how lean". Out of all the features provided by hondata, this one is the most important for people with non-standard setups.
Old Jul 18, 2008 | 01:36 PM
ReDemoN's Avatar
DixielandImports Please
Default Re: what are these features on hondata (sanimalp)
That was a nice answer.
to you
Old Jul 18, 2008 | 04:27 PM
cehcivic15's Avatar
helps alot thx
v.i.gsr
Engine Management and Tuning
Feb 10, 2012 10:52 AM
reaction360
Nov 1, 2008 07:34 PM
GetawayInMoscow
Apr 13, 2006 08:09 AM
TypeRPaul
Sep 15, 2004 12:46 PM
ceemarun
May 9, 2002 10:38 PM
