MFactory catch can install
well i recently purchased the mfactory catch can on the GB...baffled it with bronze wool so it wont corrode...but it comes with 15mm hoses. Now the question is how do u make it fit the pcv valve tightly because it is tiny inside the hose even tightened...same goes for manifold..how can i make it fit snug inside hose so i don't have to tighten too much?
use a rubber hose that was attached to it before, and double condom the fitting on there. should fit snugly that way. or u could find ur own hoses or an o-ring possibly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle »</TD></TR><TR><TD CLASS="quote">use a rubber hose that was attached to it before, and double condom the fitting on there. should fit snugly that way. or u could find ur own hoses or an o-ring possibly</TD></TR></TABLE>
Lulz.
Lulz.
