Broke radiator drain?
Old Jul 17, 2008 | 04:34 PM
Powered By Garrett's Avatar
Default Broke radiator drain?
I broke the drain plug on my Godspeed radiator. I don't even know how. Its like I drilled a hole thru it. Can I just use a bolt and plug it? Or does the hole on the plug do something for the performance of the radiator?
Old Jul 17, 2008 | 04:43 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Broke radiator drain? (Powered By Garrett)
Does not effect the "performance" of the raditor. In a pinch you can plug it with the correct size bolt. Good luck BTW.
Old Jul 17, 2008 | 05:42 PM
Default Re: Broke radiator drain? (mcvtec)
Thanks
Old Jul 17, 2008 | 05:54 PM
slowcivic2k's Avatar
Extract the shank if it broke off flush, and buy an expanding rubber plug. Those things are handy when you get oil changes that come from Jiffy Lube.
Old Jul 17, 2008 | 06:05 PM
Default Re: Broke radiator drain? (slowcivic2k)
I can still take it out, it didnt break off the head, it like, broke a hole in the end of the bolt.
tercelrcr
Jan 8, 2012 02:35 PM
ezza
Feb 2, 2010 05:31 AM
bjscivic
Jan 9, 2010 08:42 AM
Tarlacon
Nov 6, 2008 11:35 PM
vacantskies88
10
Jan 18, 2008 08:22 AM
