fixing the haze on glass lights
Old Jul 17, 2008 | 07:20 AM
crx_si-r's Avatar
Default fixing the haze on glass lights
ok i just came up another set of clear fogs, but they have a hazy look on the glass. i know i remember seeing a post on how to clean glass headlights with sand paper but i cant find it anywhere. does anyone have the link? i will post pics in a few mins. thanks
Old Jul 17, 2008 | 08:01 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: fixing the haze on glass lights (crx_si-r)
I thought 'white' toothpaste (paste, not gel) and soft bristled brush (tooth brust) was ftw. Sandpaper would be possible, but quite harsh unless v. high grit.
Old Jul 17, 2008 | 09:18 AM
crx_si-r's Avatar
Default Re: fixing the haze on glass lights (phoenix_iii)
i put my jdm lights back on for now but here is what the hazy lights look like...
both..
driver side...
passenger side...
all fogs..
im hoping to get them clear enough to replace the clear ones pictured on my car. thanks
Old Jul 17, 2008 | 11:27 AM
1989CivicSi's Avatar
it looks like all of your fogs have some very severe pitting. The only way to remove a majority of the pitting would be wetsanding with 800 grit then work your way up to 2000 grit. After that, high speed buff the lenses using cutting then polishing compound. Rotary buffer or porter cable recommended.
Realistically speaking though, I would personally just say ditch those lenses. Cutting then polishing down pitting that severe would definitely thin and weaken the glass.
Old Jul 17, 2008 | 05:29 PM
Crx Jimmy's Avatar
Default Re: fixing the haze on glass lights (1989CivicSi)
I dont think you can sand if they are actual glass. I have not tried it but it doesnt seem like a good idea, you can however spray a couple coats of clear coat overtop and it will bring the clarity back a bit
Old Jul 17, 2008 | 10:19 PM
crx_si-r's Avatar
Default Re: fixing the haze on glass lights (Crx Jimmy)
i never thought about just spraying clear coat on it. they do look almost like new when they are wet. so maybe it will work. thanks
Old Jul 17, 2008 | 11:05 PM
Spoon Sports's Avatar
Suit up
Did you get those fogs from ebay?
Old Jul 17, 2008 | 11:53 PM
tico's Avatar
Default Re: fixing the haze on glass lights (Spoon Sports)
the clear coant method wont work very wel nor last very long. the urathane chemical composistion wont stick well to it because there is nothing there for it to bite into. clear coat work for preped surfaces like paint and primer. i guarentee that even if it does bring back som shine itll fail in a few month and the reason i know this is because i paint cars for a living
machidambw
Aug 20, 2010 09:44 AM
YngMsta
Jul 6, 2010 09:20 PM
DOHC_VTEC69
Jan 26, 2005 10:57 PM
DaKINE-Ek
11
Jun 14, 2004 07:16 AM
