city lights (i searched)
Location: So Cal where old pople try to race you, U.S.A
i dont know if this is a n00b question, but i just wanted to know what city lights and what is the purpose of having them is.
TIA
TIA
overrated.
Re: city lights (dakineboiracin)
city lights are dimmer lights that you can have on instead of your bright *** headlights in well lit city streets where your headlights would be unnecessary (mostly big cities such as Vegas for example).
Most of the people that install them on here are usually for cosmetic purposes ("check out my m4d t1Gh7 JDM City Lights j00!!!11")
Re: city lights (OnePointFive)
i see. thanks a lot. is there anyone that did a write up on how to DIY your own on your headlights?
also in some of the europe, and I think japan it's required to have at least some lights on no matter if it's day or night. Also city lights have plastic lense instead of glass one so it makes them look clearer, I'm not totaly sure about that one.
I remember a while back there was a thread of a DIY with a Bronco side markers (or some other domestic truck) cant remember the thread name though sorry.
Re: city lights (AzntaggeR)
ok here you go. go to http://www.jhpusa.com they have it under 96-00 civics. under H.O.P city socket. Basically if you want to attempt this you need to drill a hole into your head light form the rear. This is rather daunting and trying to get a hole for the socket is a pain in the ***. I woudl jsut suggest buying JDM replicas that have the socket holes. Then all you need are the sockets and splice them into your turn signals.
Re: city lights (Solscud007)
thanks everyone for the help. but please if anyone knows of a link of someone trying to DIY it would be really helpful
TSPeed Factory
you can buy them off ebay for like $9. it's basically a city light bulb on the end of a bracket that fits around your h4 bulbs so when you put ur bulbs in, it pins the brack secure. then you just wire up a power and a ground wire.
here's my write up. i think azntagger described the same kit i bought.
http://www.rit.edu/~ltk6260/cityLights.html
Modified by lkailburn at 5:56 PM 6/14/2004
Re: (lkailburn)
i have a 98 hatch and i bought the "JDM" headlights (no reflector, slighty tinted headlight -- different from the black housing headlights) and they had a space already there for the city lights. I used sockets from an accord and had them wired in with my parking lights.
I have been told that headlights are not allowed in the cities of japan therefore you have to have your city lights on when in the cities. Hence the name city lights.
