5th gen's with coilovers, do you have this problem?
I've had my ground controls/illuminas for a while but the front is on the last perch and it barely covers the wheel gap. But the rears are halfway down on the collar and its the same height. Would switching the collars do anything, you guys have any other suggestions?
my d2's when the shock body is wound all the way up so the shock is as short as it gets, the rear is slammmmed but the front doesnt even tuck tyre. must be a prelude shock thing. the opposite happened with the old teins i had.
i know a lot of people with this problem including myself, i have konis and ground controls and to even it out i had to put my front on the lowest perch on the konis and the middle perch in the back, i dont know if your tokicos have perches too. that all the info i have, hope that helped.
i have tein flex i can tuck the front tires but i can drive without bottoming out on EVERYTHING in the road so i raised the front and rear right above the tire. still bottoms out in some small dips in the road. Ive read its because preludes have short suspension travel.
micah_m
Suspension & Brakes
15
Mar 29, 2011 10:54 AM
