what cams to run my setup?
Old Jul 16, 2008 | 10:45 AM
Mikes2000civicsi's Avatar
Default what cams to run my setup?
hey guys,heres a list of what i have and wondering what cams to put in
b16 head
port/polish
full supertech valvetrain(flat face valves)
port matched skunk2 intake manifold
b18c1 bottom
wiseco 12:1 pistons 81mm
running on 93 octane
wondering what cams would be good for my setup,figure the flat face would bump me up to 12.5:1 and if i should run skunk2 pro 2,thanks
Old Jul 16, 2008 | 11:13 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: what cams to run my setup? (Mikes2000civicsi)
What's the car being used for?
Old Jul 16, 2008 | 12:13 PM
Default Re: what cams to run my setup? (***$nyper)
id say a nice dd,hitting the strip 2 times a month
Old Jul 16, 2008 | 02:12 PM
Dark@Powers's Avatar
Daily driving and Pro 2's? You might already know this but just in case, your idle will be compromised..
Old Jul 16, 2008 | 02:46 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: what cams to run my setup? (Dark@Powers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark@Powers &raquo;</TD></TR><TR><TD CLASS="quote">Daily driving and Pro 2's? You might already know this but just in case, your idle will be compromised..</TD></TR></TABLE>
no it won't, not if it's properly tuned and dialed in (degreed in with pro 2's). Pro 1's would be a better choice in my opinion because pro 2's tend to like a larger bore.
Old Jul 16, 2008 | 04:02 PM
Rocket's Avatar
Default Re: what cams to run my setup? (00Red_SiR)
Running 12.5CR with 93 octane is not a good idea. This leaves no room for tuning error, if any room at all.
Old Jul 16, 2008 | 04:08 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: what cams to run my setup? (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">Running 12.5CR with 93 octane is not a good idea. This leaves no room for tuning error, if any room at all.</TD></TR></TABLE>
Yeap, what about those days when your good old 93 ain't exactly 93. People don't seem to know that octane can vary by as much as 4 points and still be legally sold at the name rating.
Plus, I don't know why people think they need the high compression in a street car.
Old Jul 16, 2008 | 09:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
no it won't, not if it's properly tuned and dialed in (degreed in with pro 2's). Pro 1's would be a better choice in my opinion because pro 2's tend to like a larger bore.</TD></TR></TABLE>
My bad, Last time I checked (a while ago) people seemed to be having trouble with them at idle. I did some research and apparently people are getting them to idle fine.
Old Jul 16, 2008 | 09:39 PM
well do u think 12:1 is better,i just wann have a nice street build,and what are the recommended tuners in nj,i know jeff evans but what are my other choices
Old Jul 17, 2008 | 06:14 AM
bump for trying to make a reliable setup
Old Jul 17, 2008 | 09:17 AM
98vtec's Avatar
moderator emeritus
where do you want your power band?
what are the rest of the supporting mods?
engine management?
Old Jul 17, 2008 | 09:18 AM
Chris Tune's Avatar
google cams are pretty good...
Old Jul 17, 2008 | 12:06 PM
JakeSpec's Avatar
if it was a 84+mm i would say sk2 p2's but on a 81mm run tuner Sk2's or blox b's
Old Jul 17, 2008 | 12:27 PM
Default Re: what cams to run my setup? (JakeSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">where do you want your power band?
engine management?</TD></TR></TABLE>
Neptune engine management,want top end,and supporting mods
2.5 exhaust,hytech replica header,3"intake with bpi stack,65mm tb
i think i will go with pro1 but i dunno if 12:1 if to high for street,
Old Jul 17, 2008 | 12:33 PM
98vtec's Avatar
moderator emeritus
i wouldnt say its too high, but the window for error is very very small when it comes down to tuning. I would advise street and dyno tuning as the part throttle ignition under load is where the engine is most likely to detonate and is where it will need the most work to be streetable.
Pro1 would be a great cam imo
You could also look into RM cams.
Old Jul 17, 2008 | 01:39 PM
Rocket's Avatar
Default Re: what cams to run my setup? (98vtec)
If would run the S2 stuff first and then if you want to try something else then RM is a good choice after getting some more experience with cams and know what to expect from cams.
Old Jul 17, 2008 | 03:22 PM
RB IMPORTS's Avatar
Toda!!
Old Jul 17, 2008 | 04:23 PM
DonF's Avatar
Default Re: what cams to run my setup? (NAKAYAMA IMPORTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAKAYAMA IMPORTS &raquo;</TD></TR><TR><TD CLASS="quote">Toda!!</TD></TR></TABLE> Why? Did you dyno tests show a differance? Please show us. It will help.
Old Jul 17, 2008 | 04:53 PM
Combustion Contraption's Avatar
Who did the port/polish on Mikes2000civicsi?
Old Jul 17, 2008 | 06:17 PM
rebo0t's Avatar
Default Re: (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">google cams are pretty good... </TD></TR></TABLE>
x2
Old Jul 17, 2008 | 06:18 PM
Runnerdown's Avatar
Default Re: what cams to run my setup? (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
Plus, I don't know why people think they need the high compression in a street car.</TD></TR></TABLE>
I couldn't agree more. A few days ago I filled up my stock daily driver civic dx and it pinged all the time at any load. I had to keep topping it off at another station until it slowly went away
And the pumps that only have one hose, I wonder how much 87 comes out before you get your 93
Old Jul 17, 2008 | 06:55 PM
patriot's Avatar
Wouldn't larger cams reduce dynamic compression thereby 'allowing' a higher compression with pump gas?
Old Jul 17, 2008 | 08:33 PM
Default Re: what cams to run my setup? (patriot)
bobs speed and machine did the port work,really nice job 2..so is a basemap chip be ok till i get it to the tuners
redflaredcrx90
Oct 4, 2008 04:04 PM
pimpintyperintegra
Nov 27, 2007 06:59 AM
delslo93
Jul 12, 2007 09:00 AM
J1A1H
26
Dec 18, 2006 07:09 AM
rough_draft
Aug 15, 2005 03:25 PM
