cars cuts off after half throttle
Old Jul 20, 2002 | 09:30 AM
SprayinCX's Avatar
Default cars cuts off after half throttle
Okay here is the thing. i took my car to the shop where there they put on a msd
blaster 2 coil. Also a new msd cap and new rotor button, a msd6al ignition, and a holley fuel pump. Now we checked the fuel pressure and everything is good. Now here is the problem when you give it gas about half throttle the will act like it is
not getting gas or something and it cuts off "dies". I was think could it bbe the computer needs to be reset or what do you think? Thanks for info.
Old Jul 20, 2002 | 10:23 AM
sammysnakes's Avatar
Default Re: cars cuts off after half throttle (1slo2k1civic)
does this happen while you are driving or when you are idleing
Old Jul 20, 2002 | 10:24 AM
SprayinCX's Avatar
Default Re: cars cuts off after half throttle (chainsaw)
not driving just idling and revving.
Old Jul 20, 2002 | 10:43 AM
did you check your main relay? sometimes the solder points crack.
Old Jul 20, 2002 | 11:13 AM
SprayinCX's Avatar
no not yet I haven't messed with it yet. I was using the search engine and came up with one other thing that it could be. The exhaust manifold has a o2 sensor in it.
the pin in the harness came out and it could that it wasn't put back in there or it is loose. So therefore it could be getting the wrong air/fuel mixture. So what do you
think.
Old Jul 20, 2002 | 04:11 PM
could be. sounds more like an ignition problem though.
civicsirebuild
Jun 15, 2011 02:58 PM
kelismod
Feb 8, 2011 09:52 PM
95blackEG
Dec 25, 2008 07:03 AM
JoHA
Jun 9, 2008 07:50 AM
H5Civic
11
May 30, 2004 05:43 PM
