car stilll turns offff
ok i have A LS fullly built in a eg.n the car shuts off very randomly,about once a day while driving.n i have changed the dizzy,main relay,n msd external coil cause i have n msd 6al.i dont know what the **** it could be?if some one has had this problem n knows what i can check or replace please lemme knoww.thanksssss.
Re: car stilll turns offff
might be your fuel pump..i had a friend that had the same problem would cut off like 2 times a day. and it was hard to get it started again,changed the fuel pump and that was it.but you can test it with a fuel pressure gauge..hope you can get it fixed
Appears to be the fuel pump. Usually when they start to go bad they'll shut off once in a while (usually when they get good and warm) but will start back up almost immediately. Perhaps the fuel pump is weak, but your filter is clogged, which would also cause this. Check your fuel filter, and change it for like $8.00 and it will buy you a few months to save up the cash for a new pump. Or if you're rich just replace them both
kelismod
02-08-2011 09:52 PM
RAAZ227
03-20-2002 09:21 PM
