h22 help
Old Jul 15, 2008 | 02:28 PM
djsire's Avatar
Default h22 help
its blowing blue smoke
and it sounds like marbles in the engine?
help?
can it be the timeing or valve lash:
how do i chekc the timing
Old Jul 15, 2008 | 02:39 PM
vlang29's Avatar
Default Re: h22 help (djsire)
did it start puffin blue and sounding like marbles all of a sudden? if so i'd pull the oil pan and look for metal before running it again
Old Jul 15, 2008 | 02:58 PM
djsire's Avatar
Default Re: h22 help (vlang29)
its been sitting for a while
the tap is new
the smoke was comin from before i put it up for the winter
Old Jul 15, 2008 | 03:51 PM
vlang29's Avatar
first i'd adjust the valves https://honda-tech.com/zerothread?id=618786
Old Jul 15, 2008 | 05:05 PM
djsire's Avatar
update!
ok i cheked the oil i was quarts shy.
when i reved the car today the smoke was mor black then anything.
onlyu comes out on upper revs, over 5500 in neutral(no load)
also the noise i beleive is coming from my alternator.
when i pressed against the alternator the noise got really quiet.
and the motor was quiet.
once i let it go the noise came back.is the a tensionor for the alternator?
Old Jul 15, 2008 | 05:20 PM
vlang29's Avatar
the belt tension is adjusted by the alternator pivoting. there are two bolts on the belt side of the alternator, and one on the front of the alternator that actually does the adjusting.
Old Jul 17, 2008 | 07:52 AM
djsire's Avatar
or could it be bad mounts?
i get a clunk sound also from a suspected bad mount
pass side
Old Jul 17, 2008 | 08:21 AM
98vtec's Avatar
moderator emeritus
post a video if possible
Old Jul 21, 2008 | 02:41 PM
djsire's Avatar
Default Re: h22 help (98vtec)
ok will do.
rhys.l
Dec 7, 2012 10:07 AM
hpi247
Jul 28, 2007 11:02 PM
djay86
11
Aug 20, 2002 07:36 PM
One8Hatch
Sep 25, 2001 05:33 PM
