Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude
Old Jul 15, 2008 | 10:39 AM
mafia's Avatar
Default Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude
Hey Guys, I just got my H22 head rebuilt (Skunk 2 valve train, skunk 2 stage 2 pro camshafts). All rebulit was done by a shop. But I put the motor back in. Anyways Code 9 go's off like 30-120 sec's after motor runs. I changed cap and roter and problem didnt go away. So then i changed the distributor And that didnt change anything. Spark plugs and wired are like 3000 miles old. Any input guys? Car is running on Hondata S300, I cant get it tuned because Any tune shop I call says they wont tune it with check engein light on. (closest tune shop is two hours aways) So i Tuned the car myself a little but nutting major. So any help will be greatly aprechiated.
ps, sorry for bad grammer english is my second language
Old Jul 17, 2008 | 04:05 PM
mafia's Avatar
Default Re: Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude (mafia)
bump, So no one knows why this code pops up?
Old Jul 17, 2008 | 04:07 PM
8_6 luder's Avatar
compression leak maybe ?
Old Jul 17, 2008 | 04:09 PM
A Blue Lude's Avatar
Exhaust cam gear not zero'd out.
Old Jul 17, 2008 | 04:12 PM
mafia's Avatar
Default Re: Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude (A Blue Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A Blue Lude &raquo;</TD></TR><TR><TD CLASS="quote">Exhaust cam gear not zero'd out.</TD></TR></TABLE>
can you explain?
Old Jul 17, 2008 | 04:14 PM
mafia's Avatar
Default Re: Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude (8_6 luder)
allright ill go cheak my compression right now. but i dont have a compression leak tester.
Old Jul 17, 2008 | 05:27 PM
BlacktraxGirl's Avatar
check the sensor on the crank. might be a slight leak in the crank seal which will coat that sensor and make it throw the code.
Old Jul 17, 2008 | 05:33 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafia &raquo;</TD></TR><TR><TD CLASS="quote">
can you explain?</TD></TR></TABLE>
cam timing.
If the timing is off, it will throw a CYP (code 9) check engine light. This is only if you are using an OBDII distributor.
If changing the distributor did not fix it, then that would be my guess.
Old Jul 18, 2008 | 02:41 AM
H22A4 crank position sensors are split between the crank snout (CKP, TDC), and the distributor (CYP). This is unlike most setups anywhere else where they will be all together in the distributor.
Changing exhaust cam timing creates a mismatch between them.
Old Jul 22, 2008 | 11:25 AM
mafia's Avatar
Well there is a chance my timing is off slighly, is there a way i can fix this with Hondata or what options do I have, redoing my timing? I had a very hard time trying to put timing belt on 100% right, So i Had my brother do it and he has done a few H22 timing belts before, I do have ajustable cam gears. Car drives good but when switching over into Vtec there is like a slight pause/lagg. thanx for all the input guys.
Old Jul 22, 2008 | 01:41 PM
Is the exhaust gear set at 0?
Old Jul 22, 2008 | 06:35 PM
mafia's Avatar
No its slightly like .5 moved to the right (cam) cam gear is moved to left. my brother said that car would bearly run at 0 but that was with stock ecu, mabe i should put it to 0 and try with hondata s300?
Old Jul 22, 2008 | 06:37 PM
holset b18c's Avatar
same problem in gsr motor running hondata s300!!!
haynes manul said that something in the distibutor is bad!!
need to try my other distributor!! if not have to do the timing over!!
Old Aug 6, 2008 | 02:48 PM
MyEfSi2Slow's Avatar
Default Re: Code 9 CYL Cylinder sensor, Is going off. H22A4 00 prelude (holset b18c)
how would you fix the timing? im having the same problem, i had a new dizzy put in, and the code still going off, its irratating, it only goes off sometimes tho, but the ecu blinks all the time,
jrv2u
Feb 18, 2009 04:08 PM
turboblack2door
Sep 2, 2008 01:10 AM
beatthisspeed69
May 20, 2007 08:36 PM
2poor2tune
Jun 23, 2006 01:38 PM
[626]95-GSR
Sep 19, 2002 09:26 PM
