Question about Greddy Type S BOV Installation
I noticed there are two (vacuum) fittings on the Greddy Type S and I am aware that one needs to go to intake manifold, but which one and where does the other fitting go?
I read on here also that connecting BOTH the fittings together will make the BOV respond faster and sound louder / better?
Here is a pic for reference so you can see the two hose fittings I am talkin about on the side of it ...
Modified by pcguy760 at 10:22 AM 7/15/2008
Modified by pcguy760 at 9:13 PM 7/20/2008
Yes its the top port. but do both for faster response.I put a nipple on my intake pipe( between bov and intake) and put the bottom one on it. I just had to take mine apart because my diaphram is busted
. hope this helps.
rajuy
. hope this helps.rajuy
Interesting... because I found this saved on PC hehe :
"My top port is hooked to the vac nipple downstream of the throttle body and the bottom port is hooked to the compressor housing. I would say the volume increases 5-10X when hooking it up like that, at least on my system."
