Wiring IAB solenoid..
Old Jul 15, 2008 | 05:28 AM
drbenne's Avatar
Default Wiring IAB solenoid..
So I'm a little confused about wiring in the IAB solenoid for my f22 to h22 swap. The guide I have says Pink to A17, Black/Yellow to 12v, Black/Red to ground. Problem is I don't see a Black/Red wire coming out of the sensor, just the pink and the black/yellow. Also where did everyone connect the 12V from. Is there a constant close by that I can tap into?? Thanks...
Old Jul 15, 2008 | 05:46 AM
pentaq's Avatar
Default Re: Wiring IAB solenoid.. (drbenne)
A17 is ground...
blk/yel connect to the thick wire going to the distributor.
Old Jul 15, 2008 | 09:17 AM
stunn'd's Avatar
Default Re: Wiring IAB solenoid.. (pentaq)
Pink to A17 and the other wire on the plug (whatever color it is) goes to a switched 12v source.. simple as that
There is and shouldn't be any third wire on the solenoid?
Old Jul 15, 2008 | 09:19 PM
drbenne's Avatar
Default Re: Wiring IAB solenoid.. (stunn'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stunn’d &raquo;</TD></TR><TR><TD CLASS="quote">Pink to A17 and the other wire on the plug (whatever color it is) goes to a switched 12v source.. simple as that
Does it matter if the source is switched or constant? I would guess the switch would happen in the ecu and the black/yellow is constant.
And to the H22 ultimate swap guide. Don't worry, it's not what i'm relying on... anyways.. they list 3 wires for the iab solenoid.
Emmanuel2112
Lighting
Apr 18, 2009 03:02 PM
raidacaipo
May 12, 2008 08:07 PM
ho bag
Mar 18, 2008 02:35 AM
Jakester9500
Mar 6, 2007 03:21 PM
red1997civic
Dec 25, 2003 12:50 PM
