RS Machined b20ITR Pistons..????
Old Jul 15, 2008 | 03:03 AM
Skunk2RR's Avatar
Default RS Machined b20ITR Pistons..????
I m looking for High CR pistons for b20vtec project..Use with stock sleeves..
What do you think about RS Machined Race Spec ITR Pistons? Anybody use ?
b16a head with b20b block.How Compression can I get?
Here is Specs.
-b16a head
-ITR Ported Intake
-Blox 70mm. TB
-JG Engine Dynamics Valve Springs
-JG Engine Dynamics Retainers
-ITR Cams w/Adjtable gears
-B20B block
-Cometic HG..vtec conversion kit
-Probe Ultralight I beam Rods w/ARP bolts
-ACL Race Bearing(Main&Rod)
and let me know what I missed??
Old Jul 15, 2008 | 05:53 AM
wesley_925's Avatar
i thonk on an 84.5 ob. with no head work. (not shavin the head), u get like a 12.5:1 cr. based on a compression calculator i used. but other things factor in like wat head gasket u use.***Balance***(everything)
Old Jul 15, 2008 | 05:54 AM
wesley_925's Avatar
sorry 12.3:1
Old Jul 15, 2008 | 07:28 PM
SuperTwinz's Avatar
Default Re: RS Machined b20ITR Pistons..???? (Skunk2RR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2RR &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> Yeah, Skunk2 Parts.
Old Jul 16, 2008 | 04:54 PM
b20vtech's Avatar
with a block not decked nor a head not milled....
B20 block 84.5mm ITR style piston w/b16 head 11.8cr
B20 block 84.5mm ITR style piston w/GSR head 12:1cr
someone plz correct me if im wrong!!
Old Jul 16, 2008 | 05:15 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: RS Machined b20ITR Pistons..???? (b20vtech)
At either of those compression ratios, the OP had better get a good tune and some decent gas because B20s aren't the most forgiving for so-so tunes.
Old Jul 17, 2008 | 12:04 AM
Skunk2RR's Avatar
I m plannig to make 210whp.I think I need Skunk2 stage2 cams..I use p28chipped ECU w/Greddy E-Manage Bluebox.
ViF CrX
Aug 29, 2006 05:48 PM
ildknyli
Jun 30, 2004 06:51 AM
Blazin Si
15
Mar 8, 2004 04:25 PM
turboex
Nov 11, 2002 11:43 AM
3rdGteg
Sep 24, 2002 07:58 PM
