RS Machined b20ITR Pistons..????
I m looking for High CR pistons for b20vtec project..Use with stock sleeves.. What do you think about RS Machined Race Spec ITR Pistons? Anybody use ? b16a head with b20b block.How Compression can I get? Here is Specs. -b16a head -ITR Ported Intake -Blox 70mm. TB -JG Engine Dynamics Valve Springs -JG Engine Dynamics Retainers -ITR Cams w/Adjtable gears -B20B block -Cometic HG..vtec conversion kit -Probe Ultralight I beam Rods w/ARP bolts -ACL Race Bearing(Main&Rod) and let me know what I missed?? |
i thonk on an 84.5 ob. with no head work. (not shavin the head), u get like a 12.5:1 cr. based on a compression calculator i used. but other things factor in like wat head gasket u use.***Balance***(everything)
sorry 12.3:1
Re: RS Machined b20ITR Pistons..???? (Skunk2RR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2RR »</TD></TR><TR><TD CLASS="quote">
and let me know what I missed?? </TD></TR></TABLE> Yeah, Skunk2 Parts. |
with a block not decked nor a head not milled....
B20 block 84.5mm ITR style piston w/b16 head 11.8cr B20 block 84.5mm ITR style piston w/GSR head 12:1cr someone plz correct me if im wrong!! |
Re: RS Machined b20ITR Pistons..???? (b20vtech)
At either of those compression ratios, the OP had better get a good tune and some decent gas because B20s aren't the most forgiving for so-so tunes.
I m plannig to make 210whp.I think I need Skunk2 stage2 cams..I use p28chipped ECU w/Greddy E-Manage Bluebox.
