hey guys are any of your cold air intakes this way..
Old Jul 14, 2008 | 03:19 PM
young_tuner's Avatar
Default hey guys are any of your cold air intakes this way..
ok well i put in a AEM cold air intake, and i was wondering did any of you guys cut the fender well to fit the tube in? heres a picture...
Old Jul 14, 2008 | 04:01 PM
Finest's Avatar
Default Re: hey guys are any of your cold air intakes this way.. (young_tuner)
Yes, I had to cut it some to get more clearance. Just remember to touch up the edges to prevent rust.
Old Jul 14, 2008 | 04:13 PM
Default Re: hey guys are any of your cold air intakes this way.. (Finest)
do you have a water bypass valve for it?
Old Jul 14, 2008 | 04:15 PM
_interLude_'s Avatar
^^x2
- i had to cut mine as well when i had a cai. its normal. alot of preluders have to do this. u might wanna spray the edges with paint or something so theres no rust.
Old Jul 14, 2008 | 05:26 PM
brad225's Avatar
yea i have one but i did not cut the car i just bent the pipe an then bent it back on the bottom u do not losse any dim. its all pref.
an if u put ur fender well back u dont need a flow valve
Old Jul 14, 2008 | 05:43 PM
Saosinx's Avatar
Default Re: hey guys are any of your cold air intakes this way.. (brad225)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brad225 &raquo;</TD></TR><TR><TD CLASS="quote">yea i have one but i did not cut the car i just bent the pipe an then bent it back on the bottom u do not losse any dim. its all pref.
i disagree. i hyrdolocked my f22 with aem dryflow filter with fender wells. if you're going to have a cai, i highly recommend the bypass. they work. and it's worth it. i just cut my cold air to short ram when i swapped my h22 in when i hydroed the f22 cause the little gain you get for a cold air is not worth a freaking motor imho. so what i'm saying is - cai = bypass or go short.
Old Jul 14, 2008 | 06:26 PM
Default Re: hey guys are any of your cold air intakes this way.. (Saosinx)
man that sucks, did you run into a lot of water? or just a little bit?
Old Jul 14, 2008 | 06:54 PM
Saosinx's Avatar
it was probably over a foot deep. it was really dark out but it was on a main road and i was trying to make it home but i came to a bottom of a hill where it levels out for a intersection and that was all she wrote.
Old Jul 14, 2008 | 08:19 PM
dagle's Avatar
instead of the bypass valve, u can just get a 2piece CAI, rainy months = connect to to the top portion and u have a SRI.. sunny weather comes along = re-attach and go.
Old Jul 15, 2008 | 12:38 AM
BlackCatt's Avatar
I noticed a noise in the engine bay shortly after my aem cai install, turned out to be the tubing tapping the edge of the hole. So i angle grinded a larger hole, carefully, gave it a undercoat of killrust and then a touch up with some red spray. I also put a piece of rubber under the hole and around the tubing to isolate the fender area from the engine bay a bit more. No real point adding the rubber but i am a bit fussy and like tinkering on my prelude. I nearly got hydrolocked in about 3/4 of a foot of water, the engine started to stall just as it got air back, bloody lucky, i will never do that again. So now i have two rules for myself when driving the Lude 1) no dirt roads, 2) no transversing water. Dagle love your setup idea, i never thought of that, but i will just stay out of the water. I rarely get any flooding where i live otherwise i would definately go sri or bypass valve.
Old Jul 15, 2008 | 01:53 AM
218luder's Avatar
Default Re: hey guys are any of your cold air intakes this way.. (BlackCatt)
Get Injen cai's they are already cut to fit. i dont have a pic to show though
Old Jul 15, 2008 | 08:03 AM
vlang29's Avatar
looks good blackcatt
Old Jul 15, 2008 | 10:22 AM
NirVTEC's Avatar
Default Re: hey guys are any of your cold air intakes this way.. (vlang29)
Just a little head ups regarding the BYPASS......when installed, power loss was about 5hp/3tq.
deinon
Jun 3, 2006 12:30 AM
redLUDEs2k1
Oct 14, 2005 06:40 AM
t o m
Feb 6, 2004 09:45 PM
civicbro
Oct 3, 2003 09:44 PM
