vvs sencer or gage cluster problem
Old Jul 14, 2008 | 10:19 AM
h22_crx's Avatar
Default vvs sencer or gage cluster problem
sometimes when im driving the speedometer works and other times its stuck on 20 wut would cause that to happen? help
Old Jul 14, 2008 | 10:35 AM
IanB's Avatar
Default Re: vvs sencer or gage cluster problem (h22_crx)
If there is a CEL, I would look to the VSS (scan the code to be sure), if there is no code, then check that the connection is clean at the harness/VSS connection, and if the problem persists, I would look at the speedo/cluster as the culprit.
Old Jul 16, 2008 | 07:07 PM
h22_crx's Avatar
Default Re: vvs sencer or gage cluster problem (IanB)
bump
Bill Andrews
Feb 22, 2019 12:18 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
confusion
May 13, 2007 02:22 AM
Mach69
Jun 3, 2005 06:50 PM
GdmLaz
16
Dec 12, 2004 03:33 PM
