Bondo on a valve cover !?
Old Jul 14, 2008 | 09:47 AM
Dyce's Avatar
Default Bondo on a valve cover !?
will bondo hold up to the heat? a kid in my area gave me a free bseries valve cover but he shaved off the honda logo and "honda motoring co" off using a grinder without sandpaper (just bare wheel ) so it looks all chopped up. i tried sanding it out but no luck. i searched and someone said use quick steel. is it sandable??
Old Jul 14, 2008 | 01:57 PM
Dyce's Avatar
22 views and not 1 reply? plz help
Old Jul 14, 2008 | 02:13 PM
zer0bot's Avatar
Default Re: (Dyce)
I used JB weld on mine and it held up fine.
Not sure about bondo though.
Old Jul 14, 2008 | 04:20 PM
DynastyRacer22's Avatar
yea use jb weld dont use bondo it'll eventually crack
Old Jul 14, 2008 | 04:42 PM
heyitzspikey's Avatar
use metal to metal its like bondo but made for high heat
Old Jul 14, 2008 | 06:49 PM
dispocrx's Avatar
metal to metal is not made for high heat.. if you want you can bring it to a welding shop and have them weld a bead in it, then grind it and block it out smooth....or you can use something like quicksteel or jb weld and paint over it...
Old Jul 17, 2008 | 12:02 AM
Sic_DA_Nine's Avatar
Default Re: (DynastyRacer22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 &raquo;</TD></TR><TR><TD CLASS="quote">yea use jb weld dont use bondo it'll eventually crack</TD></TR></TABLE>
is this first hnd exp?
I use bondo...and its been quite a long time.
no cracks...holds up fine.
Old Jul 17, 2008 | 09:00 AM
DDEVIANT1's Avatar
Default Re: (Sic_DA_Nine)
I evercoated a valve cover once, it lasted a good year, then it came off, almost pealed off. Oh and it was evercoat gold.
Old Jul 17, 2008 | 03:38 PM
phatrick2332's Avatar
I have bondo on mine, it has held up fine for the last 5 months that it has been on.
94c1v1cex
Paint and Body
Jun 5, 2007 06:56 AM
B2FiNiTY
May 9, 2006 04:22 PM
RedTegLS
Jan 23, 2004 09:34 AM
DOHC_VTEC
Dec 4, 2003 07:31 PM
devonic
Aug 25, 2003 10:10 AM
