need to remove the ball joint from the knuckle..help
Old Jul 19, 2002 | 10:53 PM
Flamenco-T's Avatar
Default need to remove the ball joint from the knuckle..help
do I just need to take the whole knuckle out and take it to a machine shop and have them press it out ?
Old Jul 20, 2002 | 06:18 AM
Chiovnidca's Avatar
Default Re: need to remove the ball joint from the knuckle..help (Flamenco-NA)
Remove the c-clip and hit it with a BFH.
Old Jul 20, 2002 | 06:49 AM
bruthaboost's Avatar
Default Re: need to remove the ball joint from the knuckle..help (Chiovnidca)
That's how I did it. However when I put in the new one, I used a piece of wood as a driver so I wouldn't damage it.
Old Jul 20, 2002 | 07:10 AM
deez92's Avatar
Default Re: need to remove the ball joint from the knuckle..help (bruthaboost)
same here
Old Jul 20, 2002 | 10:14 AM
DarkSubRosa's Avatar
BFH
Old Jul 20, 2002 | 06:42 PM
Flamenco-T's Avatar
Default Re: need to remove the ball joint from the knuckle..help (DOHC93DxCoupe)
where's the C-clip ?
thnaks guys
Old Jul 21, 2002 | 06:41 PM
the cotter pin that goes through a hole to keep the bolt held onto the ball joint under the spindle.
Old Jul 21, 2002 | 06:48 PM
LS-G's Avatar
does BFH stand for big fu@kin' hammer??
your local pep-boys or autozone will let you borrow a ball joint remover.
Old Jul 21, 2002 | 06:56 PM
Default Re: need to remove the ball joint from the knuckle..help (LS-G)
dont need a ball joint remover, thats what the *Big F@#kin Hammer* is for
Old Jul 21, 2002 | 07:02 PM
Chiovnidca's Avatar
A BFH is alot more fun.
Old Jul 21, 2002 | 07:51 PM
GruvyTune's Avatar
New User
I damaged my ball joint by usint a bfh.
I need to replace it. Are you asking how to get the actual ball joint out of the knuckle ? If so , i need to know too.
I think you need a press to get it out of the knuckle. I have a new ball joint I just need to have it replaced
Is there a way to do it yourself?
djnikko
Jun 11, 2010 10:19 AM
ultraforce77
Jul 15, 2004 02:59 PM
civcexcoupeblack
12
Sep 22, 2002 02:27 AM
Flamenco-T
Aug 21, 2002 11:49 PM
