Keyless entry
Old Jul 13, 2008 | 05:18 PM
craigaria's Avatar
Default Keyless entry
I have a 96' civic ex and I was wondering if it came with keyless entry. If it did, what controller do I need? Thanks!
Old Jul 13, 2008 | 05:43 PM
craigaria's Avatar
Default Re: Keyless entry (craigaria)
I searched and came up with no info...
Old Jul 13, 2008 | 06:11 PM
150sol's Avatar
If it came with factory keyless entry, pull the radio out and you will see two wiring plugs. If it is just one it doesn't have keyless entry.
Old Jul 13, 2008 | 06:12 PM
craigaria's Avatar
Default Re: (150sol)
It does have 2 plugs... What do I need to do to get it working again?
Old Jul 13, 2008 | 07:25 PM
150sol's Avatar
Get your remote, hold the valet button between FM/CD buttonsfor 5 seconds. you should hear the locks unlock. Then while holding the valet button within 10sec hit one of the transmitter buttons and they will activate. After they have been programed turn the ign switch off and hit one of the buttons 6 times to make them start to work.
you might find a transmitter on ebay or will need to go to the dealer.
Old Jul 13, 2008 | 07:31 PM
baller status's Avatar
You have to retain the factory stereo for the OEM system to work. If you have an aftermarket radio, chances are they didn't install it properly. Your keyless wont work and your dome light wont come on when a door is opened. The proper way is to take apart the factory radio so that it fits behind the new radio. Then install a Y adapter harness so that both stereo's are powered up. Metra and other companies make these stereo Y adapter harnesses.
Quite frankly the factory keyless module sucks and should be replaced with an alarm that has a keyless option. Then you can dump the factory stereo. When you install an aftermarket stereo, two wires in the stereo harness need to be cut and wired together. Any competent install shop should know how to do this.
This info applies only to 96-98 Civics with factory keyless.
Old Jul 13, 2008 | 07:59 PM
macson's Avatar
Default Re: (baller status)
Anyone know if there's a way to get the dome light to turn on with an aftermarket headunit other than getting the OEM system?
Old Jul 14, 2008 | 04:17 AM
craigaria's Avatar
Does it matter what remote I get? Is there a certain model that I need? Also, I found a post on this last night and is there a module that I need that hooks to the radio?
re2417
16
Jun 7, 2012 04:43 PM
jshooter
33
Sep 23, 2009 07:05 PM
viciousclipse
Jun 22, 2009 04:12 AM
Si_GReddy
Audio / Security / Video
Sep 5, 2003 07:10 AM
TexasSynergy
Feb 27, 2003 02:31 AM
