smog help!
Old Jul 12, 2008 | 10:07 PM
adobospoon's Avatar
Default smog help!
I have a d15b in my Vx hatch.
-stock p28 ecu
-97 ex injectors ( which I know is the incorrect injectors to use, but that was my last resort)
-tried wiring my 5 wire o2 to a 4 wire, but failed. So im throwing a check engine
So my question is will I still pass smog with my stock p28 knowing that it run's a bit rich and having the wrong injectors?
I know I still have to fix my 02.
Old Jul 12, 2008 | 10:42 PM
adobospoon's Avatar
Default Re: smog help! (adobospoon)
anyone.
Old Jul 13, 2008 | 07:05 AM
adobospoon's Avatar
bump
Old Jul 13, 2008 | 08:00 AM
adobospoon's Avatar
bump before church.
Old Jul 13, 2008 | 09:02 AM
Hanmin's Avatar
I think you still will, just get a 4 wire o2, or get a po7. retard your timing some too, that should help.
Old Jul 13, 2008 | 11:38 AM
adobospoon's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">I think you still will, just get a 4 wire o2, or get a po7. retard your timing some too, that should help.</TD></TR></TABLE>
so what you are saying is change out my p28 to my old p07 & run a 5 wire 02. Because P07 are 5 wire o2
Old Jul 13, 2008 | 03:09 PM
adobospoon's Avatar
Default Re: (adobospoon)
bump
Old Jul 13, 2008 | 05:05 PM
Hanmin's Avatar
yeah, either run the 5 wire and put a po7 in, or get a single vtec harness and run a 4 wire o2 with the p28. and retard your timing some. From what I've read it helps you pass emissions. but dont retard it all the way, because you will have near 0 power to the wheels. I did it before and i couldn't even get up a hill.
Old Jul 14, 2008 | 04:32 PM
adobospoon's Avatar
bumpo
CapnKrunch
Aug 12, 2007 11:23 PM
gsrturboEK
Jul 10, 2006 03:34 PM
Built B16A
Oct 18, 2004 03:10 AM
streetstylenperformance
Feb 22, 2004 09:37 PM
egizzle8
Feb 16, 2004 10:09 AM
