starter issues =(
Old Jul 12, 2008 | 09:30 PM
lilsol89's Avatar
Default starter issues =(
okay so its blazing hott outside and I try to start my car, but it won't..
and I had just replaced the starter a couple weeks ago..I don't get it!!..is it because of the heat, solenoid, or fluids??..someone help me out.
thnx
Old Jul 12, 2008 | 09:33 PM
Former User's Avatar
Default Re: starter issues =( (lilsol89)
Is the engine cranking but not firing up?
If so, is the fuel pump priming when you turn the key to ON but don't crank the engine?
Do you have spark at the plugs?
Old Jul 12, 2008 | 09:57 PM
lilsol89's Avatar
Default Re: starter issues =( (RonJ@HT)
ya i can hear the fuel pump, and I have sparks from the spark plugs
this happend to me before, when i would try and start it, i would hear nothing, no turning over at all..
Old Jul 12, 2008 | 10:05 PM
Make sure the battery is charged. Clean the terminals and connectors.
Supply battery power directly to the starter. If the engine cranks, then there's a circuit problem.
Check for blown fuses.
Check whether the switch at the top of the clutch is working, as well as the starter cut relay.
Also consider a bad ignition switch.
Old Jul 12, 2008 | 10:13 PM
lilsol89's Avatar
thanks man, will check those tomorrow
Old Jul 14, 2008 | 10:29 PM
FOMULA91's Avatar
it's usually the main relay but if you hear the fuel kicking in, the main relay is fine. Had a similar problem and it only happens during summer/very hot day.
Old Jul 15, 2008 | 07:40 AM
jdm94ej1's Avatar
Default Re: starter issues =( (FOMULA91)
it could be your ignition coil getting too hot or possibly your ignition switch IMO
obuhmyuh
10
May 4, 2010 02:15 PM
stl eh2
Dec 3, 2009 10:07 AM
eaz_e
22
Jun 23, 2009 02:39 PM
FSS13foxtrot
Apr 1, 2008 08:05 PM
AP1Shocker
Dec 8, 2006 01:27 PM
