car dies after pressing the gas pedal
Old Jul 12, 2008 | 06:17 PM
thebleek's Avatar
Default car dies after pressing the gas pedal
ok so i swapped everything in. i had a d16y7 in my 97 hatch. i swapped to an 2000 d16y8.
well in doing so i had problems with it starting. so i noticed the thermostat housing ground wasnt attached. so i did that and the car starts.
well the problem now is that the car idles high and the CEL stays on.
now i didnt wire the knock sensor or the vtec, but i doubt thats the problem here.
i can give its hardly any pressure on the gas pedal and itll climb, but wont go pass about 2000 rpms. if i give it more than a slight touch it dies.
what could this be from?
also i dont know what hoses hook into the intake manifold. there are 2 nipples on the intake manifold, one goes to the pcv valve, and below that there is another...where do i connect to/from?
Old Jul 12, 2008 | 08:59 PM
thebleek's Avatar
Default Re: car dies after pressing the gas pedal (thebleek)
bump for help
Old Jul 13, 2008 | 10:37 AM
thebleek's Avatar
anyone?
Old Jul 13, 2008 | 10:48 AM
94EG8's Avatar
Seagull Management
check and see what code(s) the CEL is throwing, then report back.
Old Jul 13, 2008 | 11:09 AM
Hanmin's Avatar
you probably got your tps and map sensor switched, pictures would help because i have no idea which hoses your talking about.
Old Jul 15, 2008 | 12:28 AM
thebleek's Avatar
Default Re: (Hanmin)
yep the tps and the map were switched. thanks everybody!
Old Jul 15, 2008 | 12:47 AM
jtegg90's Avatar
.that happened to me before i changed the cap and rotor...gud luck yo
Dunc
Oct 18, 2010 07:28 AM
thebleek
Nov 23, 2008 03:30 PM
HondaKid936
Sep 30, 2007 08:03 PM
SIckH22Atch
Aug 8, 2003 06:35 PM
