Swapped from automatic to manual Trans and the key will not come out of ignition.
Old Jul 12, 2008 | 03:31 PM
chamo77's Avatar
Default Swapped from automatic to manual Trans and the key will not come out of ignition.
The donor car was a 95 2 door with manual trans and 1.6 engine.
I swapped the engine and trans into a 92 4 door that was an automatic with 1.5.
Car runs with no issues other than the key will not come out of ignition. I believe the issue may be caused by some sort of lock related to the automatic transmition.
Is there a way to remove the lock or get around it?
Old Jul 12, 2008 | 04:04 PM
JdelMsolG's Avatar
Default Re: Swapped from automatic to manual Trans and the key will not come out of ignition. (chamo77)
so, you can still drive it?
i've never seen a problem like this unless the ignition had just buckled up. but you wouldnt be able to drive it like that.
Old Jul 12, 2008 | 04:25 PM
94EG8's Avatar
Seagull Management
did you unplug and remove the shift interlock? (blue box that bolts up where the clutch pedal goes) unplug that and yo shpuldn't have any problem.
Old Jul 12, 2008 | 04:42 PM
Fernando123456eclipse's Avatar
did u need a special mount for the tranny.??
that key thing you got to remove your sterring column and there is a lil white plastic atached to it 1 screw take that off..and ill work...am about to do mine but not sure if iam goin to need special tranny mount..lmk
Old Jul 12, 2008 | 07:40 PM
chamo77's Avatar
Default Re: (Fernando123456eclipse)
Out of the two transmition mounts (each have 3 bolts) I have only ever been able to get 4 total bolts. They never would line up.
Old Jul 13, 2008 | 06:36 AM
94EG8's Avatar
Seagull Management
To those that asked about the transmission mount, you need to either drill the spot welds out of the passengers side pocket mount and chisel it off and weld on the manual version and use the manual transmission top mount, or keep the original pocket mount and order an auto to manual mount from hasport, i think a couple of other companies make them as well. If you can weld i'd go with option 1, if you have to pay someone to weld i'd go with option 2.
blkda9123
Aug 30, 2012 11:48 AM
vsm_EJ6
Mar 20, 2009 08:53 PM
huevosrancheros
Honda Civic (2006 - 2015)
Nov 19, 2007 09:44 PM
97civicdx
Dec 29, 2006 12:10 PM
