weird noise under steering colum when starting
Old Jul 11, 2008 | 07:42 PM
blkegcoupe's Avatar
From: ....................................................................................................
Default weird noise under steering colum when starting
hey i have a 94 ex coupe and when i turn my key sometimes there is a noise like how you grind a starter by holding the key in too long but no thats not the case because its clear and in the car under the steering colum and it only happens sometimes might be wiring probs? but i never touched it before just happens recently now and i don't know only happens at random times when i just turn the key to the on position ever before i crank the car
Old Jul 11, 2008 | 09:24 PM
Former User's Avatar
Default Re: weird noise under steering colum when starting (blkegcoupe)
Loose exhaust heat shield?
Old Jul 11, 2008 | 09:57 PM
blkegcoupe's Avatar
no i said the noise is coming from under the actual steering colum i think it might be a short considering it has about 222xxx k miles on it, i just don't want it catching on fire
Old Jul 11, 2008 | 10:15 PM
Default Re: (blkegcoupe)
Okay. Possibly a clicking relay, like the starter cut relay or the main relay:
Old Jul 11, 2008 | 10:43 PM
blkegcoupe's Avatar
thanks for helping should i just replace the starter cut relay with a new one?
Old Jul 11, 2008 | 10:50 PM
Well, I'm not sure the relay per se is the problem, but it could be.
Is the clicking sound definitely coming from the starter cut relay?
Is the battery a bit weak? Is the engine cranking a bit slow on start up?
Could also be the sign of a faulty starter switch at the top of the clutch pedal:
Old Jul 12, 2008 | 08:10 AM
blkegcoupe's Avatar
i'll try both
ajun217
Nov 12, 2014 08:25 AM
caos901
Honda CR-V & Element
Jan 16, 2012 02:23 AM
areed6
Honda Civic (2006 - 2015)
Mar 12, 2011 07:39 PM
superhatchbackbros
Oct 20, 2008 04:30 PM
Daguy418
Aug 3, 2005 04:21 PM
